Old 12th September 2006, 01:06 AM   #1
Default Alternate surround repair method
Here is a why not quiestion for you.
I have a 10" woofer with a surround is starting to rot. This one has a surround that curves in toward the magnet rather than the more common outie configuration. So since the surround is still good enough to keep the VC centered why couldn't I glue a new surround over the existing one in the outie configuration and then remove the crumbling surround remains from the rear?
mike
Old 12th September 2006, 01:10 AM   #2
pinkmouse's Avatar
Well you could, but if it were my speaker, and it was getting so old that the surround was going, I'd strip it right down and clean out the gap with a bit of folded sticky tape to get out all the rubbish that has no doubt made it's way in there.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 12th September 2006, 03:04 AM   #3
The sad thing is that it was never used. I bought it for a project in HS and never even got started on it. It was on sale but the car sub never became enough of a priority. I did hook it to an amp for a few minutes just to be sure that it worked but otherwise... nada. I'm not sure that it had much chance to get dirty as it sat in the box for rwenty years.
The other interesting thing is that a replacement surround will cost more than I originaly paid for the driver.
mike
bose 901 driver surround repair replacement jaya000 Multi-Way 37 2nd September 2009 04:26 PM
foam surround repair video? unpredictable Multi-Way 6 9th April 2009 03:58 AM
What type of glue for butyl rubber surround repair? c_h_shin Multi-Way 0 19th May 2004 06:37 AM
Alternate remote volume method ultrachrome Parts 7 2nd August 2003 07:29 PM
subwoofer surround repair jbrom Subwoofers 0 3rd March 2002 10:55 PM
Page generated in 0.07538 seconds (64.79% PHP - 35.21% MySQL) with 10 queries
