3 way speaker with beyma drivers
Old 9th September 2006, 08:00 AM   #1
tpsorin is offline tpsorin  Romania
Default 3 way speaker with beyma drivers
Hello,
I want to make a 3way loudspeaker. System will be used in 4.7mx3.7mx2.5m room especially for classical music.
1.
In my town, I can listen/ buy Beyma Studio drivers.
I don't know what to choose between:
8BR40 + 5MP60N + T2010 250Hz/2500Hz 1st order acoustic crossover. Time aligned
or
8BR40 + MC115 + T2010 800Hz? / 5000Hz 2nd order crossover?
I don't need a lot of power, so I prefer to cross as low as possible, to have a good off-axis response.
2.I can also order (but without listening) Visaton, Scan-Speak drivers.
Are this one worth the price difference over Beyma drivers?
Any other suggestions are welcome.
Thanks,
Sorin
Old 9th September 2006, 11:08 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hi, with MC115 it looks like you wont need any tweeter at all, or maybe only a supertweeter above 10khz, maybe even placed on the back - but it might not be wise to cross MC115 at 800hz with only 6db - Fs is very similar to a normal quality tweeter, but it is bigger and handles low frequencies better - but 6db/12db is not that hard
Old 9th September 2006, 12:00 PM   #3
kepa1 is offline kepa1  France
This maybe a little oversized but at least it's been designed buy a speaker shop in France so you don't have to worry about crossover issues :
Dimensions h x l x p ( cm ) 90 x 36 x 40
HP Grave Beyma 12B100R
HP Médium Beyma 6MI90
HP Aigu Beyma T2030
Pente d'atténuation filtre 12
Fréquence de coupure (Hz) 380/5000
Efficacité (db) 94
Bande passante ( +/- 3db ) 37 - 20000
Principe de charge BR
Puissance RMS 150
Old 9th September 2006, 05:04 PM   #4
6dB is for first variant (with 5MP60N); if I will use MC115 then I will have 12 or 24dB crossover.
I'm not sure that MC115 does not need a tweeter. It is 5-6dB down allready at 5kHz
kepa1: 12" is too big for my room. And I don't want not to worry about crossover. Where is the fun of diy? )
Old 9th September 2006, 06:15 PM   #5
Well, every driver bumps up and down, what matters is in which manner it does it
Old 12th September 2006, 07:57 PM   #6
I have started designing the crossover using "Passive Crossover Designer" from FRD Consortium.
Two questions:
1.Why is Raw midrange phase displayed as falling from 1000Hz? (see picture)
I have entered ~ 0 for all frequecies in .frd file starting from 200Hz
2.Is there any way to reduce higher frequencies from woofer (not electrical)? Something like an acoustic filter?
Old 3rd December 2006, 12:02 AM   #7
w3eman is offline w3eman  Romania
Default Beyma
Somebody can send me the plans of the speaker with the beyma drivers, i want to build it .
Thanx
3 way speaker with beyma driversHide this!Advertise here!
beyma drivers available from import company Jarppa1st Vendor's Bazaar 0 6th July 2009 03:06 PM
FS: Beyma CP-380M Compression Drivers jeff mai Swap Meet 0 23rd January 2007 08:40 AM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 03:42 AM
Anyone used Beyma or B&C coax 8" drivers? GordonW Multi-Way 16 12th March 2005 06:04 AM
Beyma Drivers Raka Multi-Way 7 30th November 2004 06:27 PM
Copyright ©1999-2017 diyAudio
