Is ok to sell my
Is ok to sell my
Old 9th September 2006, 05:07 AM   #1
samsagaz is offline samsagaz  Argentina
Default Is ok to sell my
Hi, i owned 3 AurumCantus G2si 1 year ago, i have it in box, closed, never used it. will be ok to sell it and purchase the G2 ? i will notice any diference?
i like the G2 coz Rated power is 40w vs 30w of the g2si.
I want to use it to build an center channel and the 2 fronts of my HT, was thinking abt an 3 way for front channels and 2 way MTM for central.
You think that will be ok to use this tweeters? or maybe just sell it and prchase any dome one?
i want to use an amp for each way. and really want to sell my B&W 602 S3. Is possible to get better sound than my b&w? i really want to upgrade my system for an better one, dont want to spend money and get worst results
Old 10th September 2006, 03:15 AM   #2
Willitwork is offline Willitwork  Canada
Default Re: Is ok to sell my
Originally posted by samsagaz Is possible to get better sound than my b&w?
Yes
But it's not as easy as designing a speaker that sounds better than Bose boxes --I personally achieved this lofty goal by installing Pioneer car speakers in Tupperware containers--, however if to you DIY is simply a means to an end you can find high-end kits that will provide superior performance for less than what you paid for your B&W's, consideably less in some instances. Believe it or not B&W, like almost all speaker manufacturers, uses cost-cutting solutions in their designs, especially with regards to crossover parts. But you as a DIY'er are not subjected to those production/marketing constraints, you can opt for a no-compromise approach if so you wish.
Old 10th September 2006, 03:42 AM   #3
Andy G is offline Andy G  Australia
Andy G's Avatar
yes, in DIY you CAN get better sound... IF YOU KNOW WHAT YOU ARE DOING !!!
Will will likely NOT get it until you have considerable practice designing building your own.
I would highly recommend you do some research and find a well recognised DIY design that has been accepted as very good.
I would also start with the questions... what am I listening to, how big is the room, what am I driving them with.. a system is a system, not just individual parts.
Old 10th September 2006, 05:46 AM   #4
i was thinking abt build the Acapella SE, but dont know what spekaers can i use for center and rear channels...
The Acapellas will be ok for front stage.
Old 10th September 2006, 07:42 AM   #5
Andy G's Avatar
since Troels uses the W22, W18 and Fountek in the Acapella, it would seem sensible to use say the W18 and Fountek in the rears, maybe something similar to the TJL on his web site? It is likely to have similar tonality, being from the same designer.
Then maybe use a pair of W15's + the fountek as a centre
Old 10th September 2006, 04:20 PM   #6
well the problems is not the tweeter, i can use an g2si in the center and rears.
dont know why use the fountek intead the g2si....
Maybe can use 2 W18 + 1 g2si as center channel and the 1 W18+ 1g2si as rear?
will have enough freq range in center and rear channels?
Old 11th September 2006, 12:29 AM   #7
Andy G's Avatar
If doing HT you will always need a sub anyway, so yes, there will be enough frequency range. in centre and rear.
Old 11th September 2006, 12:35 AM   #8
ok, will try to found the specs of these drivers, dont know if use w15, w18, or w22
Old 12th September 2006, 08:13 PM   #9
150Watts is ok for the acapella SE? or will ge better with 300Watts Amp?
(i think that 300W is too much for that drivers)
Old 12th September 2006, 10:03 PM   #10
Andy G's Avatar
never have too much power (within reason).. go for the bigger one if you can afford.
its called "headroom"
Is ok to sell myHide this!Advertise here!
DIY::Sell for some IC hdmi Swap Meet 0 27th March 2009 01:31 AM
For sell TDA1541A R1 on ebay! (Auction Sell!) and TDA1543 also! bezobraznia Swap Meet 8 24th March 2009 10:53 AM
Copyright ©1999-2017 diyAudio
