I have these two Vifa drivers in MTM configuration in a 45 liter box but the sound is slightly lean. So do you think the box is too big?
#2 |
Sealed of vented box? I tried 2 x P17W in WinISD sealed box and got f3 of 80Hz using 45l vol.
Jeff |
#3 | |
#4 |
Plot shows basically whats going on. Box is 45l tuned to 40.5Hz based on your port dims. I assumed that you are using 4 ohm drivers.
Jeff |
#5 | |
Thanks. I am using 8ohm driver version. Plot shows a slight 1db dip at around the midbas region. I guess that could explain the "lean" nature of the soudn. |
#6 |
Ok, here is the 8 ohm version with the same tuning. Doesn't look that bad to me. Something else going on, crossover maybe?
Jeff |
#7 |
Well, I could reduce the tweeter just a little.
Here is the pic of the speaker: http://s47.photobucket.com/albums/f1...Anch=imgAnch10 Schematic attached. C1 is 5.7uf; R1 is 1.75ohm The simplest thing to try is to bring R1 to 2.0ohm / and or reduce C1 to maybe about 5uf. |
#8 |
Sure, or if you can get the port out and cut off 1.25", that will do it. Nice setup BTW. I like the 2-ways with the ribbons also. Is that a PP 300B?
Jeff |
#9 |
Vinylkid, have you accounted for baffle step diffraction in your crossover design??
#10 |
Sorry Noodle, not my design. What I know about this speaker is from this thread only. The crossover schem. doesn't tell us what the tweeter is, and yes BS is another issue.
Jeff |
| Must sell vifa PL18 $20 Vifa pl tweeters $30 | colwaiting | Swap Meet | 0 | 20th March 2008 03:53 PM |
| opinions on vifa pl18 tl | nebelk | Multi-Way | 54 | 5th October 2007 02:21 PM |
| New VIFA (pl18 + xt25) project | mrWagner | Multi-Way | 7 | 3rd April 2007 12:26 PM |
| Seas Excel W18 vs. Vifa PL18 | andy2 | Multi-Way | 1 | 9th December 2005 04:42 PM |
| Any one used Vifa PL18 225/8 version? | JC Fardo | Multi-Way | 11 | 27th May 2003 02:34 AM |
| Page generated in 0.09996 seconds (76.89% PHP - 23.11% MySQL) with 11 queries |
