What T/S parameters or other specifications would predict good performance with an open baffle? I have read that Qts and EBP can be used to predict suitability for a sealed or vented enclosure. Are there any similar rules of thumb for selecting OB drivers? Thank you.
#2 |
my understanding is mainly QTS, the higher the better for more bass, if you want to go loud you will need reasonable senstivity and X-max, and bigger cones generally do better (not gospel though)
more experienced people, please correct me if i am wrong...
#3 |
Custom Title
A higher Qts will tend to give you more bass energy. It also tends to correlate with a somewhat lower level of 'control', and if you're going to equalize anyway, lower Qts might work for you. Lots of displacement- either a lot of cones, or one (or several) large cones. High excursion is a bonus, if you can't get the output you want from less excursion, but higher excursion drivers usually aren't as high fidelity as lower. A large surface area moving very gently is what you want for best results.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#4 |
frugal-phile(tm)
A large enuff open baffle basically brings the system Q to the same as that of the driver. So a driver of Q 0.5 to 0.7 on an arbitrarily large baffle will work well. If the Q is less you need EQ to bring the system Q up.
If you use a higher Q driver, then you can shrink the baffle size and use the dipole rolloff of the small baffle to bring the system Q down into the 0.5 -0.8 region that is ideal. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Thanks for the good info. To rephrase my question a bit, are there any drivers to stay away from for OB? For example, the air behind an OB driver is not pressurized and does not act as a spring to limit cone excursion, as might be the case in a box. Would certain drivers be at particular risk for reaching the limit of their excursion and bottoming out on an open baffle, compared to the same driver in a box?
#6 | |
frugal-phile(tm)
dave
#7 |
Some more things to consider, which you will not find in the specs:
The driver should be sufficiently vented. Excessive noise from the pole vent for example will not bother in a closed box, but in OB it will. If you are considering dipole for the midrange too, you should look for an "open" basket and a rather unobstrusive magnet. So you will not compromise the radiation to the back. Rudolf
www.dipolplus.de |
| L-pad attenuator for midrange driver 6 1/4 inch driver | rhythmdiy | Multi-Way | 0 | 4th November 2007 03:32 PM |
| Base driver to suit ESS Heil driver | gerado | Planars & Exotics | 6 | 1st August 2007 07:56 PM |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Driver/ driver configuration improve soundstage width | andy2 | Multi-Way | 6 | 16th June 2005 08:47 PM |
| mtm versus tm driver recommendations on project with $500 driver and xo part limit | gsattler | Multi-Way | 4 | 20th May 2002 05:54 PM |
| Page generated in 0.08456 seconds (79.92% PHP - 20.08% MySQL) with 10 queries |
