Multicells horn with BMS
Old 6th September 2006, 04:50 PM   #1
hugobors is offline hugobors  France
Default Multicells horn with BMS
Hello,
I've red with interest that some people used the coax BMS 4590 or 4592nd with success.
My question is if this kind of CDs can work great with a 15 cells horn (like onken 200wood) or if this kind of horn is better in a low-mid only configuration (maybe bms 4591) + super tweeter.
Because to achieve 220Hz or so, I think multicells horn is the best way to go for directiviy.
Hugues
Old 6th September 2006, 10:45 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Salut Hugues -
Those BMS drivers are cool.
Maybe you can get BEAR to answer. He should know about them. I know that he runs compression drivers down to about 300Hz - but don't know what drivers he has used.
Please post photos of whatever you do.
Bonne chance!
Take the Speaker Voltage Test!
Old 10th September 2006, 12:32 PM   #3
Brett is offline Brett
Brett's Avatar
Default Re: Multicells horn with BMS
Originally posted by hugobors
Hello,
I was probably the first person here to get the 4590 into a custom system in 2000/2001. Great drivers but I 've never tried them in an Altec style multicell. Used hypex (Arai 290), tractrix (270Hz, HPF at 400), conical. and some old EV and other flares I had lying around. The reults and 'best' will depend on the rest of the system and preferences. I don't like using them below 400Hz unless the flare will support loading better down to this freq.
Used in a suitable flare (try a cardboard or artist board conical first) there is nothing that I've ever heard that's better.
Old 10th September 2006, 10:05 PM   #4
Thanks for your answers,
Brett, what is your prefered flare with your 4590? because finaly I will not make multicellular (I've red elsewhere that this kind of horn is not good for a wide frequency bandwith).
Do a 150Hz circular tractrix can do a good job with this CD?
Hugues
Old 11th September 2006, 12:10 AM   #5
Brett's Avatar
Hugues
150 is too low. A 270Hz flare for a 400Hz cutoff is as low as I'd go.
I like conical best, but it depends on the rest of your system and personal preferences.
Old 11th September 2006, 01:48 AM   #6
GM is offline GM  United States
GM's Avatar
Greets!
At a glance the 4591 will do fine on a multicell rated for a 300 Hz XO and EQ'd flat to 7 kHz, then add supertweeters positioned between them and bassbins to top them off. The 4590, 4592 will load the mids, but getting good distribution of the highs to all the cells could be problematic, so IMO not combos to invest any time/$$ in unless you already had the horns available to experiment with.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th September 2006, 09:55 PM   #7
Thanks everybody,
But brett, what you think about this : www.bd-design.nl (go to plug and play and to orphean).
It's a tractrix round horn with 4592ND that goes to 220Hz...
Old 11th September 2006, 10:52 PM   #8
Brett's Avatar
It looks like it only sells as a complete system, and at a stupidly expensive price. Even if it gets a decent frequency response down to 220, that's no guarantee that it will sound good down there. The 4590 doesn't ime. Looks like hes's trying to stretch the FR down as low as possible to match with the existing type BR LF system. Trying to milk the lowest LF response from a CD isn't neccessarily the best choice sonically (not just with these drivers). I'd personally run a good cone/1" coax on an Oris 150.
Old 17th September 2010, 04:31 PM   #9
jaskierster is offline jaskierster  Poland
I have this driver BMS 4590 and will mach it with 350 JMLC horn, how low can I cross it ?
Old 18th September 2010, 01:40 AM   #10
soho54 is offline soho54  United States
The 4594ND and its 1.4" throat would work better for the highs.
Multicells horn with BMSHide this!Advertise here!
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 9 19th August 2012 07:29 PM
Single Driver Horn Base Port from Frugal Horn EmergencyDpt Swap Meet 0 26th October 2008 02:24 AM
RCA MI-1425 with MI-1469 Horn, MI-1457 (W-horn) with RCA MI-? fieldcoil woofer thekop-bkk Swap Meet 0 26th September 2008 04:55 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 06:06 AM
Copyright ©1999-2017 diyAudio
