For a couple of years now I've been tweaking a 3-way dipole speaker consisting of Monacor SPP-250 woofers, Peerless 850490 8" HDS driver as midrange and the B&G Neo8 taking care of the rest. Overall the sound is quite pleasing, except for the 8" HDS, especially from 500-1500hz, so now I'm looking for something else.
Crossover points have been around 150-300 hz and 1-2kHz, depending on the settings in the DCX2496. Speakers are running fully active. Seas CA22RNX and Ciare HW 204 both look interesting, but it's hard to tell just from a datasheet. Another option could be two 6-7" drivers in a D Appolito configuration. From some car speakers i accidently came across the Monacor Predator 6, available both in both 4/8 ohms, with smooth and extended frequency response. Maybe that could be it Would be tempted to try something more "exotic", like the Ciare, so any opinions would be welcome. I'd want clean sound up to 1,5kHz at least. Low frequency extension is really not that important as I have separate woofers anyway |
#2 |
Hello
Why don/t you take a look at the the Phoenix project (Linkwitz lab), for a d'appolito configuration. It uses scan-speak drivers. If not, maybe the 7'' seas excel, but it comes with a price. |
#3 |
Thanks, I've been looking at Linkwitz's site to get some ideas and it's been quite helpful, especially about the dipole behavior.
Did forget to mention the price, as it's a factor, would be willing to spend around 150-200 euros in total, so the seas excel will unfortunately be out of question. |
#4 |
The d'appolito configuration (with proper drivers) will give you a power handeling posibility (without having distorsions) quite similar with the excel. I am thinking that the phoenix is a fairly researched project so you should get the results you are after... of course I'm not shure if the scan-speaks are in your price range either...
Best luck! |
#5 |
Monacor 5.5" SPH-130 is said to be very good, and cheap; there is a SPH-175 but dont see it be any better fore this setup
#6 |
I have some doubts about a 5.5'' in an open baffle... even as a midrange...
#7 |
If cost is a factor you might like the Dayton RS series, the 7" will get you a higher crossover point and the 8" will get you a lower cutoff. These drivers are known to have low distortion, and there are many designs using them out there with reviews and measurements.
Im using two of the 8's as mids in a 4-way. |
#8 |
The Peerless 7" Exclusive seems to do a good job in John K's NaO Mini.
http://www.musicanddesign.com/NaOMini.html |
#9 |
#10 |
How about this new 6.5" , looks interesting, huge Xmax, flat impedance, wide FR...all accounts for a quality motor...and cheap too
http://www.ascendantaudio.com/poly_6.5_page.html |
| INCREDIBLE 12" woofer-midrange SE friendly, lowest distortion-2khz...MUST READ!!!! | Spiritzly | Multi-Way | 17 | 29th August 2010 01:05 AM |
| 10"woofer Recommendations | sdaudio2 | Multi-Way | 20 | 12th November 2007 12:05 AM |
| Please recommend a 15" woofer for a dipole | navin | Multi-Way | 91 | 4th July 2007 05:20 AM |
| Closed back midrange drivers 4" maybe 3" - recommendations please | RobWells | Multi-Way | 2 | 22nd February 2007 04:59 PM |
| Page generated in 0.10724 seconds (78.34% PHP - 21.66% MySQL) with 10 queries |
