Old 5th September 2006, 07:23 PM   #1
Default Line Array diy suggestions
Hello, I'm considering building one of following: 1) GR Research/CSS Alpha LS 2) Selah Audio or 3) one of Jim Griffin's designs.
My room is 13' x 22' and the speakers really cannot be more than 3' from baffle to the front wall. Listening position is about 12' away.
Ported or sealed? 5.5" or 6.5"? "Normal" tweeters or planers? Or other options (ie, a line array with the tweeter in the middle because of the room constraints)?
Thanks in advance.
Old 6th September 2006, 02:31 AM   #2
Your room is a very nice size and arrays will sound just fine in it. Sealed speakers can be placed a little closer to the walls than ported in general. A custom design could also include the appropriate amount of baffle step compensation to account for your placement as well. Now realize that moving any speaker away from the front wall will yield better imaging and cleaner sound but you have to live with the set-up and likely WAF factors.
If you have subwoofers then I would go for smaller mids but large mids in ported cabinets can work without subs. Of course you can equalize sealed arrays to pick-up the bass in-room without subs as well.
I like planar or better yet ribbon tweeters for line arrays. Especially, the 6-7" long ribbons used 8 or 9 per side. With your room size I would highly recommmend that you don't use just a single tweeter per side.
Old 6th September 2006, 06:45 AM   #3
Jim, thanks for the response. I'm inclined to go ported and then, if needed, add a sub. I'd prefer to build a proven design as opposed custom building the array.
Do you have any specific designs/suggestions for a 6 ft. two-way array using 6.5" and the aforementioned 7" ribbon or planers for tweeters at around $2k for drivers?
Old 6th September 2006, 11:15 AM   #4
You should contact Rick Craig at Selah Audio.
www.selahaudio.com
Old 14th January 2011, 11:41 AM   #5
adason is offline adason  United States
adason's Avatar
So which one did you built, and how do you like the results? Post some pics.
Looking for line array suggestions Danse Multi-Way 19 21st July 2005 03:38 PM
Line array wiring suggestions mazeroth Multi-Way 3 12th April 2005 11:28 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
t-line subs for a DIY line array tom1356 Multi-Way 17 28th December 2002 12:15 AM
Page generated in 0.08805 seconds (71.02% PHP - 28.98% MySQL) with 10 queries
