In an attempt to make the B3S's even smaller, could one use an aperiodic membrane? Then decrease the cabinet volume maybe 2/3 or 3/4. I would of course have to play with the baffle step. But my ears are not tuned terribly well, so I dont need perfection. Any thoughts would be appreciated.
#2 |
frugal-phile(tm)
Surely worth a try... we are just embarking on a similar project with the CSS FR125S -- we'll see how they work stuffed into a 4 litre enclosure.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
AFAIK, in order for an AP to be effective it needs to vent into a volume separate from the driver, because it's out of phase. If you want really small why not try dipole?
Dan |
#4 | |
frugal-phile(tm)
dave
#5 | |
I'd also question the logic in going dipole with this driver, i think the excursion limits, by the time you'd equalised everything would severely limit output. I thought aperiodic vents basically acted as an acoustic resistor between the inside and outside of the box, simulating the effects of a larger box (air inside the box becomes more compliant), at the cost of a higher f3 and a steeper 18db/oct roll off. |
#6 | |
frugal-phile(tm)
http://homepage.mac.com/tlinespeaker...nAperiodic.pdf dave
#7 |
The Vas of of the B3S is 0.8L, the box volume 3.2L. Box volume is not part of the design, its actually lazy re-use of existing boxes which the article should make more clear. Aperiodic loading is pointless as as stated they should be used with an active crossover, sealed box loading down to 1L is fine. Baffle step changes should not be an issue, with same baffle width. For full range use the Aurasound driver is the 3" bass champion. |
#8 | |
frugal-phile(tm)
Pretty good eleswhere as well -- and if you want to guild the lily, it plays well with the Apexjr $1 tweeter. dave
#9 | |
Hear the real thing! |
#10 | |
According to: Parts Express And: Solen The VAS of the B3S is 1.6L or 0.06 cu. Ft. The box volume of 3.2L is double VAS, this doesn't seem "lazy" to me. It seems like a reasonable box size. Sure it could be smaller, but 1L is surely too small. -Jim |
| Aperiodic boxes with aperiodic TL's - an idea. | Shoog | Full Range | 0 | 22nd May 2009 05:03 PM |
| Looking for reviews of Zaphs SR71 kit. | garage1217 | Multi-Way | 17 | 20th February 2008 09:24 PM |
| zaphs impedance measurements | omni | Multi-Way | 3 | 5th July 2006 06:41 PM |
| Engine air filter for aperiodic membrane? | Datoyminaytah | Multi-Way | 12 | 20th July 2005 11:07 PM |
| Zaphs W3-871 notch filter? | Kram | Full Range | 18 | 4th July 2005 03:14 PM |
| Page generated in 0.11016 seconds (86.97% PHP - 13.03% MySQL) with 11 queries |
