I'm looking for a recommendation. I want to switch many amplifiers to many speakers. Basically these three settings:
Serious listening - quad amped system - 3 speakers L& R & sub Background listening - as above but cut out one amp for my delicate Ionovacs Home theater 5.1 - all of the above This is going to have to be custom. I don't want one of those commercial switchers with autotransformers or load resistors. So I need to find appropriate relays for the purpose. Anyone know what kind/manufacturer is best in terms of low contact resistance/wear and current capability? |
#2 |
Your explination is not very clear, how bout a diagram of what you want to do?
#3 |
No need for a diagram. I just need a recommendation on what type of relay to use with the contacts rated to handle power amp outputs and with really good contacts.
#4 |
search / research relays suitable / used in power amplifier protection circuits and you should find something suitable. Alternatively you could use a bank of manual switches. |
#5 |
RDR, let us know what you find.
I need to do an amp swithing setup, too. Not as fancy as yours, but finding relays with quality contacts would be nice.
Take the Speaker Voltage Test! |
#6 |
A search here was of some help, but no parts #s. I am now going through Mouser and all the manufacturers they sell. Looks like some 16-20 amp DP/DT 24 DC coil relays might do, but I'm not sure about the contact material. Contact fouling over time is a factor. I'll report back later.
| Rail Switching vs. "predictive" rail switching | rtarbell | Solid State | 5 | 4th March 2007 10:26 PM |
| High Current relays for speaker switching? | Zero Cool | Everything Else | 13 | 15th December 2006 11:52 PM |
| Switching | s0rce | Parts | 0 | 20th December 2002 11:09 PM |
| ESL amp - switching amp? | Altaic | Solid State | 9 | 28th July 2002 10:43 PM |
| Switching multiple 5.1 speaker systems? | Marcus | Everything Else | 2 | 14th March 2002 12:19 PM |
| Page generated in 0.09487 seconds (74.74% PHP - 25.26% MySQL) with 10 queries |
