I am designing an 11l reflex enclosure and wish to have some idea of the effect of using wadding on the tuning frequency - I am planning on using 4cm thick cotton woll on all internal walls except the front. What sort of percentage virtual volume increase can I expect (just a rough guide). Thanks
Keladrin |
#2 |
Did it Himself
None if you are just lining the walls. A reflex box should not be stuffed either, just lined, or you restrict the reflex action.
The lining will just damp the mid and treble down.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Thanks Richie,
I am a bit confused now though as I have read some websites that say differently - for instance: http://home.new.rr.com/trumpetb/audio/fboxjs.html
Keladrin |
#4 |
the volume increase effect you refer to is used for sealed box cabinets. The air inside a reflex (ported) box needs to be able to resonate for the reflex action to work as predicted. The lining is there to control the reflections as stated by Richie. Keep it as thin as possible. Why avoid the front? Use it on all flat surfaces including any bracing.
regards Andrew T. |
#5 |
Thanks Andrew,
But what is the website I mentioned on about when it indicates the change in virtual volume for he bass reflex enclosure? Thanks,
Keladrin |
#6 |
I include some information form another website that clearly indicates that damping materialk effects port tuning so please clarify: Damping material: Vb = 29.5 litre Scan-Speak 8" bass driver. vent: 72 (ID) x 200 mm Fig. 9. Impedance of bass driver with no damping (blue) and heavy damping (red). Heavy damping here means 10 mm polyester foam on all internal panels and 2 sheets of Monacor MDM-3 added - and not blocking the passage to the vent! The MDM-3 is a great material consisting of 2/3 sheep's wool and 1/3 polyester fibre. As can be seen, the addition of damping material has a significant impact on the impedance profile and the vent tuning is lowered from 37 Hz (no damping) to 33 Hz (heavy damping) and no surprise here. Again damping material increases the virtual volume of the cabinet and has to be taken into account when deciding Fb and vent length. Thanks,
Keladrin |
#7 |
The volume increase depends on the amount of stuffing. For reflex boxes the amount of stuffing can vary but the stuffing must be kept away from the port mouth, e.g. for a tall floor stander with a low port stuffing the top half of the box is quite normal. For a lively reflex you generally only line the box, which should not be kept as thin as possible as stated, it should be as thick as is reasonable, I'd say a minimum of 1/2" but 1" is much better quality foam. In a small box 1" will be a very significant proportion of the internal volume. Lining the box will increase Vb ~ 0.2 x the above propotion, i.e. for 50% = ~ 10% and if you use BAF or similar behind the driver but away form the port perhaps another 5%. My boxes are moreorless completely filled with acoustic foam with the area near the port filled with BAF and the port still operates but at a reduced level (Musical Fidely MC2s). I believe it is like this because Q is marginal for reflexing. |
#8 | |
well what can I add? Your research clearly shows that damping can be used to tune a reflex. Quote:
regards Andrew T. |
#9 |
Thanks Sreten,
You have been a great help.
Keladrin |
#10 |
I agree (as usual) with sreten
Stuffing a box has two effects. 1. The box appears bigger due to isothermal compression/decompression of the air. If the box is completely filled with an ideal isothermalizing material, the volume increase is 40%. In reality it is less. 2. The stuffing adds resistive losses, which typically lowers the Q values of the various resonances in the system. Both the above are true for both closed boxes and bass-reflex boxes. For the bass-reflex (1) is great help, it means that the box can be made smaller. (2) on the other hand is both positive and negative. First it can reduce the amplitude of the standing waves inside the box. That is good. Second, it adds resistance also near the port tuning frequency. This is bad. The result of this resistance is that a larger box volume is required for a given frequency response. In other words, this counteracts the positive effects of (1). From the above one can understand that a bass-reflex box should have some amount of resistive damping, in order to kill the standing waves, and this can be acheived with fiberglass or similar. A large portion of the remaining volume can be filled with a material that has a low resistance, but a strong isothermalizing effect, such as polyfill (I think that is the english name for it). And the space near the port should be left completely free of stuffing, due to the high air velocities there. |
| Effect of wadding in opening of dipole | Dr.EM | Subwoofers | 11 | 26th March 2009 10:07 AM |
| Wadding / stuffing | Howard | Subwoofers | 6 | 9th January 2006 08:50 PM |
| Subwoofer cabinet filling & net volume increase | dis | Subwoofers | 0 | 4th July 2004 03:51 PM |
| Help with wadding | cmwcmw5 | Car Audio | 0 | 28th January 2004 08:47 AM |
| By how much can fiberglass actually 'increase' enclosure volume?? | sardonx | Multi-Way | 23 | 17th January 2004 08:16 AM |
| Page generated in 0.12573 seconds (80.04% PHP - 19.96% MySQL) with 10 queries |
