Old 1st September 2006, 02:13 AM   #1
Cloth Ears's Avatar
Default A quick, dumb question on time-alignment
If you have a front-loaded horn mid, and a ribbon tweeter or a high-efficiency mid-bass - how do you locate the horn to time align? Do you still line up the voice-coils, or do you treat align the horn mouth with the other drivers and delay the mid-bass at crossover?
Told you it was a dumb question
I've got some dome mids that I can build some 7cm horns for (13cm dia) - and, as usual, I was just wondering...
I couldn't find any relevant post, so if there is one, just point please.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 1st September 2006, 06:55 PM   #2
In general, the effective source location on most all transducers is at the voice coil or at the bobbin to cone adhesive joint. So, the entire horn would need to overhang in front of a direct radiating driver at crossover.
This all presumes that the units are minimum phase devices and also assumes you'll be addressing the the acoustic output of the devices and not expect an idealized theoretical crossover will give the expected results (meaning you'll include the response roll offs of the transducer when designing the crossover ...which is usually a significant effect with horns near and below their LF cutoff).
Old 1st September 2006, 07:23 PM   #3
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
By experiment i.e. measuring summation and simulating it, we can draw conclusions of propagation centres from phase tracking. It shifts a little for different frequencies. In the critical midrange around 3kHz I have seen cones having their origin of sound at about 3/5 their cone depth and tweeters & compression drivers with horns at about the join of dome with coil point.
Old 5th September 2006, 09:08 PM   #4
myhrrhleine's Avatar
Measurement works best.
It can also be done 'by ear' if you have the know-how, but it's rather imprecise.
Old 25th September 2006, 07:17 AM   #5
Cloth Ears's Avatar
Nee How! Sorry for the late response, been in Shanghai.
Thank you for the replies... damn! I knew I would have to do some work instead of there being an easy answer.
Jont.
Quick Dumb question K-amps Pass Labs 45 24th November 2006 05:58 PM
time alignment? flaevor Multi-Way 7 18th August 2006 12:51 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
Time alignment question Simon Multi-Way 29 23rd September 2001 07:46 PM
Page generated in 0.08693 seconds (74.83% PHP - 25.17% MySQL) with 10 queries
