Old 22nd December 2002, 02:35 PM   #11
Troels, I belive U
I suppose that 100sl have a kind of equalization or whatever
in the Xo that makes SM150 go down to 400 Hz.
What is the lowpass for SM150 in your speakers?
What do U think about comparision of SM150 with another
mids? (PHL, Focal etc, etc)
Thanks and regards,
Spherion
'Miracles are miracles, faith is faith and life is life'
Old 22nd December 2002, 03:44 PM   #12
Volt driver
I´ve got a Volt driver for my bass. I use two Volt Studio Range B2508 each in a sealed 28 dm³ box. It is very fast and powerfull.
The best bass driver I ever heard, also Fs is only 50 Hz. I use a 6 db activ filter with an 100 W/8ohm silid stat mono amp. Simply great!
regards
Günter
Old 22nd December 2002, 03:59 PM   #13
You mean the one with 8mm Xmax (B2500.8)? I've been thinking about
this driver for bass but came to a conclusion that I need something BIGGER (like 12" or 15").
However, Volt drivers are really noteworthy - REL uses them,
for example.
Well, for my next home speakers (when I sell esl's) bass driver
will be probably mounted in a sealed enclosure...
...selection of drivers is pretty wide, but I have three types:
ATC SM 375 SC
Volt (one of the 'Radial' series probably)
and Visaton TIW360 (very cheap here in Poland for the specs)
Don't know yet whetrer I'll use active correction, but if I will,
I'll rather go for all-active amp/Xo circuitry
Spherion
Old 2nd December 2003, 07:43 PM   #14
Send a message via AIM to b_online Send a message via MSN to b_online Send a message via Yahoo to b_online
Default Have a look at this...
www.kingston.neostrada.pl
(Project 10)
I am putting money on the side every single month for it,,,,,,
I hope to build them in a year maximum time (hopefully)
They simply look like the most promising loudspeaker I have seen in a very long time.
B
Old 2nd December 2003, 07:59 PM   #15
ATC SM 375 SC
i have a pair of this super woofer - as new - for sale......shoot me a mail.
Old 2nd May 2011, 07:44 AM   #16
tantang is offline tantang  Indonesia
hi.... sir anyone demension atc sm 75 150 s, real size....pleass
Old 2nd May 2011, 08:10 AM   #17
ShinOBIWAN's Avatar
Did tantang just win the prize for oldest thread resurrection?
Old 2nd May 2011, 08:57 AM   #18
i think so
tantang actually have a valid question. seems no one has the drawing dimension of them.
cheers
henry
For Sale: 2 x ATC SM75.150S dkxdn Swap Meet 8 17th July 2008 09:26 PM
xover for atc sm75-150s montana Multi-Way 2 8th July 2007 05:25 PM
ATC SM75-150s x-over design help? T-Dot Multi-Way 2 4th January 2007 08:02 AM
Fs: Atc Sm75-150s triode4 Swap Meet 1 7th September 2006 01:55 AM
wanted : ATC midrange SM75 150S Vil Swap Meet 0 15th March 2005 07:39 AM
Page generated in 0.10434 seconds (72.21% PHP - 27.79% MySQL) with 10 queries
