Hi all,
I'm about to start my 2nd speaker project and need some help in deciding what drivers to use. I will be building a 3 way design, 10", 5" and a 1". My budget for the drivers is about AU$600 approx for all 6 drivers. So I'm after the best performing drivers that can be purchased in this budget. Any ideas would be much appreciated. Once I decide on the drivers, I will move over to the Enclosures and Xover designs. So what do u think??? |
#2 |
Custom Title
What sort of goals do you have for the speakers? There are quite a few choices in that price range, though I'm not sure what drivers are available to you without disastrous shipping costs. Are you looking for high efficiency? Deep subwoofer style bass? What speakers have you enjoyed in the past? One combo I think you could do very well with would be Eminence Alpha 6A and the new peerless HDS tweeter.... then you'd have a pretty darn good amount of budget left to find a good high efficiency woofer, you'd probably want 96dB so that it has inherent baffle step correction, and just cross over to the mid at that frequency. I'd suggest a 15" though, a high efficiency 10" is a midrange, not really a midbass or bass driver.
The alpha and the peerless have low distortion and are reputedly good sounding (you can get away with a 2k XO with the peerless, a big plus) and are 93dB efficient. But you won't get super deep bass from a 93dB 3 way with a flat 8 ohm load like this would turn out to be.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
Given your assumed level of experiance, i think that it would be a very good idea to build this as a sub/sat combo, Design, or use an existing design for the top 5in + 1in tweeter. Then using an active crossover cross in to a subwoofer on each side. Doing things this way imho has a much higher chance of success (3 way designs can get very complicated very quicky), and you can do things in stages, instead of one big project without anything listenable for a long time. I would also suggest that you pick drivers that have been used in a published design before (for the 1in and the 5in), or common drivers, your chances of help are much higher this way, or if the worst came to the worst you could scrap your enclosures and use someone elses design completely.
#4 |
Peter from RZ Audio http://www.rzaudio.com/about_us.htm is probably your best bet for DST (Vifa, Peerless) drivers.
Have fun ! |
#5 |
http://www.acousticconcepts.com.au/ is also good for Seas drivers.
#6 |
did you know that Acoustic Concepts, aka Aranmar Acoustics will soon be carrying the "Hemp" brand drivers?
#7 |
Interestingly enough, most of the lobbying done against growing hemp in western countries (the THC content of select breeds is low enough that it is useless to smoke or bung in a bong) was supposedly done by dupont, since nylon was a primary competitor.
#8 |
Yep, the big companies, synthetics, fuel, etc etc have a lot to answer for by holding back development in many areas, just to protect their products from competition. It stinks !!
But this is not a political arena, so I say no more !! |
#9 |
Hey Andy, didn't you build something with hte peerless hds and seas 27tdfc kind of like i did? How did you go?
#10 |
you mean these? Peerless 850439 x 2 + Seas 27TBFC/G
The guys loves them !, and yep, I think they turned out rather nice !! http://users.tpg.com.au/users/gradds/brettHT.jpg;) |
| driver selection help | dallaire | Multi-Way | 4 | 2nd December 2007 08:02 AM |
| Need Help with Driver selection | Jlace | Car Audio | 2 | 24th March 2007 07:26 AM |
| 3-way driver selection | boostin1989 | Multi-Way | 2 | 6th June 2006 06:58 PM |
| 2-way driver selection. | jazzbearz | Multi-Way | 5 | 6th February 2005 05:25 PM |
| Driver Selection help. Please! | jainbaby | Multi-Way | 17 | 10th April 2004 02:04 PM |
| Page generated in 0.10231 seconds (80.70% PHP - 19.30% MySQL) with 10 queries |
