Old 29th August 2006, 06:11 PM   #1
Default Heavier = better?
When building speakers is it worth adding extra weight with sand and/or lead?
It would be in an extra compartment completly sealed from the main enclosure.
Old 29th August 2006, 06:46 PM   #2
gary f is offline gary f  Canada
gary f's Avatar
My feeling is that heavier is better. But the enclosure must be rigid and not only heavy.
F
Old 29th August 2006, 06:57 PM   #3
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
If it helps dampen panel vibrations then yes. If it just makes the whole thing heavier and the panels are able to ring just the same then you haven't gained much.
The other school of thought is to use comprehensive bracing to push panel resonances higher up then use stuffing to absorb them. A less ugly approach imo.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Why are Hammond SE OPTs dissed? Heavier than the competition... awedio Tubes / Valves 105 5th November 2009 04:18 PM
heavier duty upgrades for tip110 and tip115 crippledchicken Parts 2 2nd August 2004 03:00 AM
Page generated in 0.07854 seconds (68.18% PHP - 31.82% MySQL) with 10 queries
