One question - I am about to rebuild my boxes (using seas excel drivers) and came to an idea to offset the speakers so that I get some time alignment. What am I unsure about: does the benefit of better time alignment outweigh resulting diffraction issues? Another idea was to round the woofer flange but as a result the distance between speakers rises.
The design is here - http://higherground.negercity.cz/dx/vezicka02.gif |
#2 |
Custom Title
The stepped baffle you propose would be fairly disastrous in terms of diffraction issues: a symmetrical ring like this is a big no-no. You can do 'time alignment' many ways, one is to move the tweeter off center towards the outside of the cabinet, or to do a slanted baffle- I think that a slanted baffle is in many instances the best choice for a normal 2 way with a dome, and then you simply make sure that you have the drivers at the appropriate height for on-axis listening in your space. I am fond of high efficiency tweeters, which generally means horns or ribbons, and a nice thing about them is that the motor is generally further back from the mounting plane, meaning: "time aligned" more easily. If you're really concerned with getting the tweeter and midwoof close together, I'd think carefully about what sub-baffle arrangement works best (perhaps an angular coupling
Avoid symmetrical baffle mounting at all costs- everything should be offset, preferably at "golden ratio" intervals to further disperse reinforcement/loss/etc.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
Thanks Badman, I have thought so after reading some Rod Elliott's article earlier today. I know of benefits of ofsetting the drivers, but since the baffle is pretty narrow, I kept it centred (in the drawing) sofar.
Which way would you prefer - to slant the enclosure or go active and introduce some delay on the tweeter? |
#4 |
Those who prefer domes over ribbons and horns may use waveguides like Genelec does.
Monacor for instance does even sell a waveguide matching one of their dome tweeters ! Regards Charles |
#5 |
Custom Title
Well,
The active option has many positive points. I don't introduce active delay in my active crossover, but it's a perfectly valid approach. I do prefer to use somewhat wider baffles though, the slender baffle approach requires so much by way of baffle step correction....
| DIY Time Alignment. | clipto333 | Car Audio | 32 | 4th January 2011 05:48 AM |
| Time alignment circuit? | Bad silver | Car Audio | 4 | 30th January 2007 08:00 AM |
| time alignment? | flaevor | Multi-Way | 7 | 18th August 2006 12:51 PM |
| is doing time alignment now a waste of time? | Beggar | Multi-Way | 9 | 28th July 2003 05:45 AM |
| Page generated in 0.08322 seconds (72.78% PHP - 27.22% MySQL) with 10 queries |
