I have a pair of old speakers. Is there any way that I can check the efficiency of them?
Thanks |
#2 |
The only simple way is to compare them to some known references. |
#3 |
The not-so-simple way would be to measure them.
You would need a signal generator with amplifier, a multi-meter, and an SPL meter. You can use your PC as a signal generator; there are many free programs that will generate arbitrary sine waves. I assume that you have an amplifier already. You just need to adjust your output sine wave to be 2.83 volts peak-to-peak, then measure the SPL at one meter. This will tell you the sensitivity. If you want to know efficiency, then adjust the voltage such that your speaker is dissipating one watt. |
#4 |
diyAudio Chief Moderator
Maybe you meant Vrms?
#5 |
Speakerholic
I agree with sreten. Put them up against a known set and do an A/B comparison. While it won't give you a number, it will tell you if they are more or less efficient/sensitive.
#6 | |
Dan |
#7 |
sorry for my poor background of electronics....
What is a SPL meter? Thanks |
#8 |
SPL = Sound pressure level, measured in decibels at a given distance and axis from the speaker.
| Measuring a speakers efficiency | pjpoes | Multi-Way | 14 | 30th January 2009 04:35 PM |
| high efficiency speakers for 2A3 | moo | Multi-Way | 23 | 25th February 2006 04:04 PM |
| ZEN brothers and low efficiency speakers | jh6you | Pass Labs | 6 | 24th June 2003 04:35 AM |
| Efficiency of Two Speakers in Series | markkanof | Multi-Way | 17 | 2nd May 2002 07:37 AM |
| High Efficiency Speakers | markkanof | Multi-Way | 17 | 9th January 2002 07:00 AM |
| Page generated in 0.10384 seconds (74.22% PHP - 25.78% MySQL) with 10 queries |
