I have been speaking to a couple of B&W dealers and they say that the 803s/803d have 3 crossovers inside the speaker box, is this true? Crossover High Crossover Medium Crossover Low (Obviously other models may have this aswell, but I am talking just about the 803 range) How on earth do they connect together? My understanding is that the speaker cable comes in from the amplifier and hits the crossover and then is passed onto the speakers, thats with 1 single crossover, how do they connect 3? without having 3 inputs? Is there a main crossover that pushes it to the other 3? so there is 4 in total? |
#2 |
harrisni, I think you definately still have a long way to go if you want to emulate the performance of the 800 series with your own designs. I would strongly you go for a kit or published design first.
What the B&W dealer ment by three crossovers is that the speaker has a three way crossover. The "Crossover High" rolls the tweeter off at the bottom end, The "Crossover Medium" rolls off the Kevlar midrange at the top end (to corrispond to the tweeters roll off) and again in the bass region. The "Crossover Low" rolls off the midrange and treble of the bass drivers. |
#3 |
diyAudio Chief Moderator
#4 |
HI,
Thanks for the reply, He said there are actually 3 crossover boards in the speaker box. HI/MED/LO |
#5 |
the sections for the networks were simply on seperate boards then, functionality is the same
#6 |
#7 |
Yea I find seperating the boards really helps with organization and prevents mis wiring.
#8 |
Are there 3 sets of inputs on the back?
They could be separated for multiple amplifiers. |
#9 |
Hi Nick,
Some fundamental knowledge is required before you build loudspeakers. If you are interested in speakerbuilding, I strongly recommend you pickup a book like Vance Dickason's LoudSpeaker Design Cookbook, or Speakerbuilding 201 and learn some basic speaker terminology and the basics of electrical circuit theory. As noodle snacks alluded to, the 3-way crossover are connected in parallel. That means that internally, the single input wire is split into 3, and run into each of high, bandpass and low pass filters. Whether the layout of these filters are implemented as 1, 2 or 3 physical boards is entirely up to the designer, and electrically, makes no difference. regards, Thanh. |
#10 |
Not sure about this, but here is a picture of the crossover for the B&W 802D
| Crossover for vifa 2 way setup - how can I find out what this crossover is doing? | Tino | Multi-Way | 11 | 17th May 2009 04:21 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Mission: Build sounding speakers then B&W 803s | harrisni | Multi-Way | 3 | 18th December 2006 06:58 PM |
| What should I use for a crossover? | punkrokr1701 | Everything Else | 1 | 10th September 2006 07:27 PM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Page generated in 0.10819 seconds (83.04% PHP - 16.96% MySQL) with 11 queries |
