What could cause a patina on the front and rear surfaces of driver cones (SEAS mag cones) ?
Don't know how clear these are: http://img.photobucket.com/albums/v3...S/photo023.jpg http://img.photobucket.com/albums/v3...S/photo021.jpg Thanks |
#2 |
Looks like oxidation to me.
#3 |
That's what I was thinking. Er what effect might that on the sound ~ presumably not good (by much??)
Cheers |
#4 |
zero to none
#5 |
FullThrottleRic, or anyone
are you sure - sounds odd to me? cheers |
#6 |
Go claim warranty !
#7 |
Custom Title
I'd anticipate extremely small influence on sound (probably none)- the surface texture hasn't changed significantly, nor should the mechanical properties of the cone.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#8 |
So there are bits of oxidation on the cone? How could that happen? Is magnesium prone to oxidation? What about other metal cones, such as aluminum how prone are they to oxidation?
#9 | |
It doesn't look like any problem at all.
".........These go to eleven" |
#10 |
When Magnesium oxidizes, much like aluminum, it creates a thin layer of oxidation. The oxides of magnesium and aluminum are ceramic and prevent further oxidation (why aluminum doesn't "rust").
Unless you are welding or making electrical connections, it is perfectly normal and fine. The thin layer of oxidation will prevent further oxidation better than any paint covering of the same thickness and weight. Therefore, it is probably best just to leave it unless the aesthetics bother you. I think some companies actually advertise the thin layer of ceramic oxidation as being beneficial (Klipsch on their aluminum cones?). If the layer of oxidation becomes more than just a patina, there is probably some sort of chemical on the cones causing that oxidation, which needs to be removed. Magnesium is very reactive- just try placing it acid or setting it on fire (violent exothermic oxidation)- but that thin layer of ceramic oxidation keeps it from rusting through. It should be fine for a speaker cone. |
| What glue to use for cone? | Vivek | Multi-Way | 12 | 29th August 2008 09:47 AM |
| Cone weight vs Cone stiffness | musgofasa | Full Range | 9 | 25th July 2008 08:16 PM |
| Sub Cone material | skooter | Car Audio | 24 | 23rd November 2007 07:53 PM |
| Making a cone | rjb | Full Range | 24 | 28th February 2006 09:24 PM |
| Page generated in 0.09725 seconds (76.20% PHP - 23.80% MySQL) with 10 queries |
