I have produced the following measurements, but in general have failed in my waveguide experiment, and keep racking up problems.
Refer to http://www.zaphaudio.com/hornconversion.html for background. I tried a new mounting method whereby I sink a screw head in epoxy in the wells formed by the waveguide ribs. I added epoxy over three days, and let it dry thoroughly. As soon as I mounted the tweeter to the waveguide, the epoxy completely separated. Anyone know a better material to bond to abs for me to sink screw heads in? After that failure, I just mounted the tweeter using screws compressing it onto an old baffle. I got some haphazard measurements of before and after. My goal for this experiment was to find the difference in magnitude in order to develop a notch filter so I can update my crossover when I finally get working waveguides. The measurements are done using TrueRTA in my room, raw measurements are shown, as well as those smoothed using a 30 average forward and backwards running average. This should be adequate to get some starting crossover values to work from. Zaph was right, the second rib of the waveguide is pretty much spot on for the Seas 27TDFC. I'd like to ask if anyone would be willing to modify some of the mcm horns for me. I asked the superviser of the machine shop in my engineering department at school if she or one of her students could quickly help me when they had the chance. She flat out told me to go away. I'd rather not wait until the school year to get a friend to do it under the table for me, and don't want to have anyone face her wrath. I did the first modification by putting the waveguide onto a drill chuck and turning it with a saw, an extremely dangerous diy lathe. This would be quick work for anyone with an actual lathe. Besides the danger and lack of precision of my stupid method, the abs needs to be machined faster than I can do, or it deforms. Sorry about the cropped picture, diyaudio limits the resolution, and I didn't want to rerun the scripts and format it again. |
#2 |
It's such a shame the tool shop is idle most of the time. The fellow in my lab that builds all our setups does ridiculous things by hand because the supervisor hates him.
#3 |
A router, straight bit and an appropriate jig is all you need to modify the MCM horns. Maybe you should try approaching a relative or a local woodworking club or something. You need a box that is open on two sizes, big enough to slide the horn in, with a third opening on the top, using a straight bit take off small amounts (testing with the tweeter itself) until you have it the right size, its not difficult as long as you are careful. Let me know if this doesn't make sense.
#4 |
I actually talked to a buddy here with a router, and he was uncomfortable about the brass insert. I know brass is easy to machine, but any special advice for the router? Do you just go around the brass? I feel real uncomfortable telling other people just to go for it.
About your box instructions, I'm getting the idea you just make a box to put the face of the horn back flush with the face of the router baseplate? |
#5 |
Cut the brass section off with a hacksaw or similar first. I'd take 3mm passes with the router until i was within 3mm, then adjust in very small steps from that until it is just right (if you are clever you can do the final pass on both at the same time and save a fair bit of fiddling). The box would basically let you place the horn face down with the router on top (sort of like the badly drawn attached picture, you should be able to see the horn underneath with the platform for the router)
#6 |
Thanks, I need a better hacksaw.
#7 |
I dunno. Quick judgement based on the fact that you're interested in something that I also happen to be.. and that I've had very similar run-ins with supervisors of depts in schools who really should NOT be in the position they inhabit for such a lack of interest in student's wholesome curiosity..
..but I think you ought first to write a letter to some higher authority in your school and see if you might add some weight to any other discontent she may have generated up till now. Ref this forum. Maybe she's hugely talented, but she might be better off laboring away in a cubicle on some widget that really needs her attention instead of disappointing the ambitions of her students. I could be wrong. Maybe you're just a pest. But I doubt it. Personally, I've been toying with the idea of using one of the MCM waveguides to cast a mold so that I might make a concrete baffle. Nylon inserts could be cast in place to match the tweeter mounting holes. |
#8 |
Hi Mazurek,
My method for cutting down the MCM horns was to cut with a hacksaw and then grind to the desired throat opening with a belt sander. It worked perfectly and only took 10 minutes to do! A belt sander will cut through metal or plastic quite happy. Personally, I've abandoned the idea of using the MCM or similiar horns as a wavegiude for a dome tweeter as it doesn't really work very well. Cheers, Ralph |
#9 |
bluebeard, I agree that the school has a problem. The mechanical engineering machine shop does not even let students in whatsoever. The industrial engineering machine shop at least offers a class for students, which I took. I don't know why the people that run them are so negative towards student projects, the same superviser that shot me down yesterday was incredibly helpful and positive when I took her class.
raphs99, please explain to me what you have moved on to. I thought the MCM horn as a waveguide as a good idea to deal with diffraction issues in a larger baffled speaker I'm making. The woofer dictates the baffle to be at least 11.5" wide. Do you use compression tweeters. I understand there are many out there that are of excellent quality, but am very unfamiliar with them. |
#10 | |
| Zaph waveguide TMM rebuilt | Animalnisse | Multi-Way | 52 | 16th November 2007 11:17 PM |
| Anyone completed a Zaph 2.5 waveguide? | neutron7 | Multi-Way | 9 | 19th May 2007 07:54 PM |
| Zaph Waveguide Questions & Issues | EDDIEMUNSTER | Multi-Way | 9 | 18th March 2007 11:27 PM |
| Zaph's TMM 2.5way Waveguide | demon2091tb | Multi-Way | 1 | 20th October 2006 06:05 PM |
| Zaph's L18 or Waveguide? | xyrium | Multi-Way | 10 | 10th August 2006 12:51 PM |
| Page generated in 0.12586 seconds (81.83% PHP - 18.17% MySQL) with 11 queries |
