Old 22nd August 2006, 04:05 PM   #1
Default multidriver sensitivity
In a tmm or mtm type of enclosure, how do I handle the attenuation circuit for a crossover?
Is it different if the m's are series or parallel?
Thanks.
peace,
memphissound <><
Old 22nd August 2006, 07:35 PM   #2
Well, I found a spreadsheet that gives me the numbers here:
http://www.soundhobby.com/
But I still don't understand how it "works", if you will. How I might work it out on paper.
peace,
memphissound <><
Old 23rd August 2006, 01:10 AM   #3
Send a message via MSN to noodle_snacks
Basically speaking putting the two m's in parallel will net you an impedance of half the original value and give you 6db of additional output, putting them in series will double the net impedance and leave you with the same output for amplifier level. This will also effect the crossover components you will need to select in order to cross them over.
The best way to handle the attenuation circuit of the crossover without measuring equipment imho is to buy a L-pad and adjust until it sounds right, note the values then replace with appropriate resistors.
driver sensitivity vs system sensitivity bvan Full Range 12 5th November 2007 07:57 PM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 11:33 AM
Sensitivity dB Calculations 69stingray Multi-Way 4 5th July 2007 12:25 AM
Sensitivity and efficiency? sachi Multi-Way 16 7th February 2005 03:22 PM
Multidriver impedance load Steen Multi-Way 1 2nd August 2001 12:46 AM
Page generated in 0.08769 seconds (71.66% PHP - 28.34% MySQL) with 10 queries
