I have some coils which I have no idea what the milihenries are.
Without going and buying a meter to measure them what type of businesses might have this capability that I can go and ask them for a favour? Would an electric motor company be able to do this ya think? Thanks for any suggestions Dave. |
#2 |
If you can handle the steep learning curve of Speaker Workshop, you can use it to measure the coils yourself. All you need is a computer and about $10 in parts.
Dan |
#4 |
Bob, thanks for those links ~ is there a web page about them on that site too?
#5 |
Dr. Steber published the linked article in the ARRL magazine QEX. You might find other interesting articles at www.arrl.org.
#6 |
Hi Dave,
If you run up against a brick wall, I can measure them for you. That's unless you have a ton of the darn things. I use an Agilent 4263A LCR meter. Last resort. -Chris |
#7 |
As a quick and dirty you can always use one of those freeware signal generator programs for the pc and a simple voltage divider with the coil in parallel with a resistor. Adjust frequency until voltage across each is equal. At that freqency the coil has the same imped. as the resistor. Then use Z=2*pi*L=R. So L=R/(2*3.1415)=R/6.283.
You might have to try a couple of different sized resistors to get a reasonable frequency. This is not as accurate as a bridge but will get you in the ballpark without having to build a bunch of stuff or figure out the complexity of a bridge. mike |
#8 | |
So, when the voltages are equal, Z=R. Now Z is the vector sum of Xl and Rl but for an air core inductor of the type usually found in crossover networks, Rl may be small enough to ignore so Xl=R. But, if you want to be absolutely accurate, measure the DC resistance and apply the formula Xl=SqRoot(Z^2/R^2) Also, you have to factor the test frequency into the math. Xl=2*Pi*F*L. Transposing gives L=Xl/2*Pi*F. You could try electronics repair shops in your area to get them measured or find a local ham radio operator who would be willing to help. Cheers Rob |
#9 |
My bad. I shouldn't try to post when I am sick.
I meant series and I left out the frequency term. I was lying down and it hit me so I returned to correct it.L=R/(2*pi*f) as Rob pointed out. mike |
| How to measure inductance in the x-over. | marchel | Multi-Way | 3 | 12th December 2007 11:23 AM |
| How to measure small inductance? | lumanauw | Solid State | 21 | 12th January 2007 11:44 PM |
| measure inductance | henryp | Parts | 2 | 5th July 2006 10:44 PM |
| LCR meter to measure inductance | SimontY | Parts | 14 | 22nd April 2004 04:47 PM |
| How to measure inductance? | Jimmy154 | Multi-Way | 41 | 20th July 2003 03:37 AM |
| Page generated in 0.15093 seconds (71.83% PHP - 28.17% MySQL) with 10 queries |
