Monacor SPH kevlar midranges
Old 19th August 2006, 12:38 PM   #1
Virtalahde is offline Virtalahde  Finland
Default Monacor SPH kevlar midranges
I've been trying to find some test data around the web for the SPH135KEP or SPH165KEP kevlar drivers, without luck. Especially interested in distortion and off-axis measurements.
Monacor's datasheets suggest the on-axis response is extremely smooth up to ~10 khz, I wonder if there's any truth in the datasheets..
Old 19th August 2006, 01:52 PM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
They does look very smooth
But SPH-165KEP seem to have a dip around 6khz but falls off smoothly, and with a moving mass at 17g it seems very likely, but definately an interesting driver
SPH-135KEP....what I doubt most is its rated sensitivity at 89db
Old 19th August 2006, 04:34 PM   #3
Vedo is offline Vedo  Croatia
Here you are!
Monacor sph-165kep
Old 20th August 2006, 09:14 AM   #4
Vedo, thank you a lot!
I kinda suspected that.. The off-axis response isn't all that great and I wouldn't cross it higher than 2k5. It's a 6,5"driver , so a lower crossover point would be probably better anyway.
Is the T/S data measured by this magazine? The moving mass seems way off, 12g against the stated 17g?
Old 20th August 2006, 10:29 AM   #5
Any time!
I think that measurments are made by Klang&Ton magazine in Germany.I also bougth this driver.It will be matched with Scan Speak 9500.
Old 23rd August 2006, 01:56 PM   #6
isamac is offline isamac  France
Yes it is accurate, at least on the two 165KEP I got.
Fs is more around 45Hz than the stated 30Hz.
The response is smooth up to 5/6Khz with little breakup.
The only concern with this unit is that a high volume, there is an air leak around the plug, which makes some noise.
Old 24th August 2006, 08:52 PM   #7
borys is offline borys  Ireland
borys's Avatar
Maybe I can help with meas of 165kep.
TS a new driver:
Response:
THD at 1kHz (meas of my speakers, crossover at 3kHz):
And my speakers:
Crossover point IMHO could be at 3kHz and below. It is a great driver, I think it is better than vifas 18cm xt/xg.
If you need I have meas of: 165c/cp, 130al and prapobly 200ke.
Old 24th August 2006, 11:04 PM   #8
I guess I would "attack" it around 4khz (6db with double RC)
Old 7th February 2007, 05:00 PM   #9
ssstromar is offline ssstromar  Slovenia
Question exact dimensions
Does somebody have more precise dimensions of the SPH-135KEP or maybe SPH-165KEP would aslo be adequate. I ma looking at theese drawings and can't make much of them: http://www.monacor.de/de/PDF/G/G1/G102410/G102410Z.pdf
What does 133x133 mean? Is it 133mm measured at units narrowest point or at the wide part.
Thank you in advance
Monacor SPH kevlar midrangesHide this!Advertise here!
kevlar reconing dazfj Multi-Way 4 26th January 2009 01:34 AM
6.5" ReSponse Kevlar Woofers f4ier Multi-Way 18 15th August 2005 01:46 PM
any good kevlar mid-woofer? samsagaz Multi-Way 7 25th September 2004 02:03 PM
Two Eton 5-880 5" Kevlar Woofers Tony D. Swap Meet 1 1st September 2004 09:34 PM
Focal 4k Kevlar mids mikeatfhc Multi-Way 15 23rd December 2001 07:38 PM
