If I place the Seas 27TBFC/G tweeter within 12 inches of my CRT monitor, it starts distorting the picture. I want to add enough shielding to be able to place the tweeter within 6 inches of the monitor.
From doing searches, the options seem to be bucking magnets and iron cups. A few posts mention either of these methods can change the behavior of the driver, but no details about how. Parts Express is having a buyout on bucking magnets, so this seems like a good choice. However, I have no idea which one to use. Should it be the same size as the 80mm magnet on the Seas tweeter, or smaller? Any ideas on how it will change the behavior of the tweeter? Dan |
#2 |
Approximately 50% to 70% of the size of the main magnet. But note this is by weight, not linear dimensions, a magnet with 90% dimensions of another is 70% smaller, 80% is 50% smaller. Adding it will increase BL by ~ 7%, increasing output by ~ 0.5dB. |
#3 |
The C in 27TBFC/G means chamber. It means that your bucking magnet might not be quite as effective and will likely have less impact on output. Removing the chamber will drastically change the response - don't do it.
A 27TBFC/G messes up my 19" monitor at about 8" above it, while putting two back to back I could move in to around 4". I have 27TDFC in a metal cup that seems quite effective - 2" from a 32" TV and no interference. The metal cup must be thick to be effective. I bought mine from zalytron for $15 - designed to fit Focal drivers, it was called a "Silent Shield" IIRC. Not sure if he still has them. |
#4 | |
Didn't even think to check this, good spot BE. At distance you need a smaller magnet to cancel the residual magnetic field but you also get more leakage. You could try a steel plate in the side of the box. |
#5 |
I have to order some other parts from PE, so I will try the bucking magnet first.
The magnet on the 27TBFC/G is 72mm diameter and about 14mm tall. The cup is 20mm tall, so I'm going to try the 60mm x 32mm x 8mm and 60mm x 25mm x 8mm magnet from PE. At less than a dollar each they are very economical. Dan |
| Adding a bucking magnet, what effects does it have | pjpoes | Multi-Way | 2 | 9th November 2008 05:49 PM |
| SEAS 27TBFC curiosity | PeteMcK | Multi-Way | 5 | 19th November 2007 02:23 PM |
| Need help: Seas 27TBFC/G | Mrpong | Multi-Way | 1 | 4th January 2006 11:26 AM |
| bucking magnet ? | woody | Multi-Way | 2 | 14th October 2002 03:51 AM |
| Bucking magnet question | woody | Everything Else | 1 | 1st June 2002 07:55 AM |
| Page generated in 0.07503 seconds (75.95% PHP - 24.05% MySQL) with 10 queries |
