Old 18th August 2006, 07:38 PM   #1
Tenson is offline Tenson  United Kingdom
Default Small subwoofer drivers like 5" Tangband
Hi guys,
First question is, what do you think of the Tangband W5-1138SG?
I am thinking of building a small, well mini, monitor. I want to try and get as deep bass as possible from about a 5-6liter cab for the bass. I don't need huge SPL but I would like it as high quality as possible.
I was thinking of using the W5-1138SG and then using a active bass boost to give about +6dB at 40Hz. It can take about 30watts RMS so that should be alright for normal listening levels in the near-field I think.
I was waning to Xover 1st order (2nd if I have to) around 400Hz to the w3-871's I have so it needs to not have a bad lower midrange either.
TB are about the only people I could think of who make drivers for boxes that small but if you know of other good drivers please let me know. Anything up to 6” is alright and I will have about 30watts of power.
Old 18th August 2006, 09:53 PM   #2
Pano is offline Pano  United States
Pano's Avatar
I have a buddy who builds a lot of speakers and he was raving about these (or maybe it was the 6.5" version) recently.
He says they will play low, loud, and clean. But not very efficient.
I'll drop him an email about them, see what he says and which version he is using.
edit: He says:
It's the 6-1/2 W6-1139SC, the older version of the current 1139SG. Don't know why they changed it.
A little more Xmax with the SG.
So if you can go with the larger dirver, it should make you very bass happy!
Take the Speaker Voltage Test!
Old 19th August 2006, 02:08 AM   #3
Thanks, I did consider that but it didn't have quite such deep bass in a 6 liter cab. However, it does have twice the power handling so if I could get more amp power I can more than make up for it Super mini speakers here I come!
Maybe I should start a new thread for this but are there any good and cheap amp modules that give about 50watts? I was planning to go with a 25watt 41Hz Amp3 kit, but if I use the 6" driver I should go for more. I know there are gainclone amps about that power so any recommendations for cheap and good modules? I would prefer digital though really so they are more efficient.
Old 19th August 2006, 02:09 AM   #4
Dag is offline Dag  Sweden
Dag's Avatar
This is a very good solution for a small sub!
Peerless SDS 5¼″ + 2 passive radiators in 5l.
http://www.tymphany.com/datasheet/appview.php?id=17
Old 19th August 2006, 06:19 PM   #5
Hmm it looks like that solution is about 5dB down at 70Hz already, or am I missing something? Is there any more information on it, have you made one, got any pictures?
Thanks!
Old 19th August 2006, 09:15 PM   #6
Pano's Avatar
As for my buddy who uses the W6, I'll contact him again. He did say that it was in a box that shouldn't work with a port tuning all wrong, but sounded great.
Will see what info I can get.
Old 19th August 2006, 09:53 PM   #7
Thanks mate, I was thinking of going closed because a port down at about 40Hz just won't fit in a 5L box unless its diameter is tiny and I am going for quality here.
Old 20th August 2006, 01:53 PM   #8
Dag's Avatar
"Hmm it looks like that solution is about 5dB down at 70Hz already, or am I missing something?"
-- No you are right. But the sensitivity is better! It can play "very" loud down to 50Hz because of the passive radiators. But, it is not very good below 50Hz. TB is much better there.
The midrange is also good so you can use a tweeter crossed at 3k
D
Old 20th August 2006, 02:26 PM   #9
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Here is Part Express's Selection for woofer in that cabinet size. The second to last column is the net internal volume of a ported enclosure, the last column is the F3 point.
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 20th August 2006, 03:29 PM   #10
Maybe it's too expensive but anyway...
Adire Audio Extremis 6.8 http://www.adireaudio.com/Home/ExtremisMidwoofers.htm
Very promising performance
http://www.zaphaudio.com/6.5test/
http://206.13.113.199/ncdiyaudio/mar...rs_blowout.htm
Q=0,71 in aprox. 10l sealed box with average stuffing
In 5-6l box I would advise to use with Linkwitz transform circuit
8" Subwoofer Enclosure Part 2 (with thiele-small now) hernanstafe Subwoofers 10 7th February 2007 02:45 AM
8" Drivers for a small U-Frame Tenson Multi-Way 11 7th January 2007 02:27 AM
WTB: a small 8" or 10" subwoofer justpoor Swap Meet 0 26th February 2006 09:05 AM
Can four of 8" drivers build up a subwoofer? Peleus Subwoofers 15 15th May 2004 04:22 AM
Suggestions for small (8"/10") subwoofer driver? netgeek Subwoofers 17 22nd December 2003 06:01 PM
Page generated in 0.11751 seconds (76.36% PHP - 23.64% MySQL) with 11 queries
