Old 18th August 2006, 03:01 AM   #1
mpmarino's Avatar
Default Tannoy/Dayton 3 way...comments/suggestions?
Hi folks,
I intend to build a loudspeaker system for 2 channel and occasional movie watching. It needs to be musical and very dynamic...gee, thats a surprise huh I think I can do it, I'll be throwing a lot of hardware at it. I need guidance as to which way to throw said hardware. I've intended to start on this many times for the past year but amplifier projects kept working thier way to the top
I plan on using a Tannoy K3148 coincidental for the top and a Dayton Titanic 12 for the bottom. The speaker will be a single dual chamber 'chassis' with the sub built in. It will be completely active 24dB LR, with an Adcom 555MKII for the daytons. The amps for the tops will be whatever I have built at the time that I feel like hearing
Top chamber:
1 ft3 for the Tannoy K3148. This driver models terribly in 1ft3 as you can see in the red line on the pic. Now, I would like to try an aperiodic vent to lower the Q. I am thinking that since I really am not interested in bass extension I could lower it plenty and smooth it right over. Tannoy spl:woofer-~93dB / tweeter- ~103dB
Bottom chamber:
2 ft3 for the Dayton 12 MKIII. Front facing. I am in the usual quandary here. I am strongly leaning towards vented as I would like to keep the sensitivity of the 'sub' up closer to that of the Tannoy. I know I'll be giving it plenty of power but I'd like to use as little of it as I can. The green slope is that of the Dayton in a 2 ft3 box tuned to 23hz. Dayton SPL 88.6 dB 2.83V/1m.
Please guys, I could use constructive criticism.
Do you think this will work?
Do you see a fatal error?
What am I forgetting about?
Should the vent should face front or rear?
Thanks guys.......
edit: the Tannoy has a 12" woofer
Crazy Yankee.
Old 18th August 2006, 09:34 AM   #2
what red line ? with a 24dB/oct c/o Q probably doesn't matter.
/sreten.
Old 18th August 2006, 12:13 PM   #3
mpmarino's Avatar
Thanks for looking Sreten,
Yuo don't see a red curve in the graph which represents the Tannoy? ..or are you saying with 24dB it's irrelevant?
Any comments truly appreciated.
I will probably get only one chance at the build....
Crazy Yankee.
Old 18th August 2006, 12:55 PM   #4
sorry, I can see the faint red line.
Depending on your c/o frequency, if you want the tannoy roll
-off to be true 4th order L/R acoustic then you can build an
active crossover that electrically sums with the box alignment
to give the required acoustic response. That is a somewhat
overdamped 2nd order active filter + underdamped box 2nd
order roll-off = 24dB/oct 4th order L/R acoustic high pass.
edit : also with 2cuft for the Titanic III sealed box Q is 0.67
which is far too high for good quality reflexed bass, IMO you
should use the III sealed and let room gain bump up low bass.
/sreten.
Old 18th August 2006, 01:35 PM   #5
mpmarino's Avatar
Thanks,
sorry for all the questions. The last speak I built was 18 years ago
I understand what you mean for the Tannoy.
>Maybe planet 10 can comment on the aperiodic idea ???
For the Dayton you stated that in 2 ft3 sealed the Q of .67 is too high. Isn't the goal .707 which would be somewhere around 1.5 ft3 if I were to go sealed? Are you suggesting go somewhere around .5 Q for power handling reasons etc? This wouldn't be somewhat boomy?
I'm not arguing...just probing
Hey thanks...
Crazy Yankee.
Old 18th August 2006, 02:33 PM   #6
Sealed box Q of 0.67 is too high to reflex for good bass.
Target for a sealed box is generally Q = 0.6 to 0.8 depending on taste.
Q=0.5 is completely damped and would give very tight bass and
a very room friendly bass roll-off, but can need a much larger box
than say Q = 0.6 depending on the driver.
The lower the sealed Q the less boomy it is.
My target for your speakers would be sealed Q = ~ 0.65.
The aperiodic loading of the Tannoy is pointless due to the c/o.
/sreten.
Old 18th August 2006, 03:36 PM   #7
mpmarino's Avatar
Thanks very much for the advice. I'm much closer now
Crazy Yankee.
Old 18th August 2006, 03:40 PM   #8
tinitus is offline tinitus  Europe
http://www.partsexpress.com/pe/pshow...46&rak=295-190
nah, maybe not
Old 20th August 2006, 06:48 PM   #9
mpmarino's Avatar
I wonder if it would be Sacrelidge if I tore apart a perfectly good set of Infinity RS4B (1980's) and used the shell for this project. They sound unimpressive to me and I think the parts are worth more than the sum. I love the appearance and would spend way too much time duplicating it. Is it a coincidence that internal volume is perfect...or is it destiny?
Crazy Yankee.
suggestions for tannoy 15in gold kirbyt Multi-Way 7 14th January 2007 11:21 PM
New 4 way project comments/suggestions? FullThrottleRic Multi-Way 37 21st September 2006 12:11 PM
my first try at a LM3886 layout, any comments/suggestions? BrianGT Chip Amps 281 15th June 2005 11:21 AM
Need comments and suggestions for this amp. hienrich Solid State 2 6th January 2005 09:55 AM
Page generated in 0.13280 seconds (79.65% PHP - 20.35% MySQL) with 11 queries
