Old 18th August 2006, 02:27 AM   #1
Default Good inexpensive tweeter
I'm looking for a good inexpensive tweeter for a 3 way loudspeaker. I like the softdome tweeters.
I have found this Peerless and I like it because it is a wide angle and it should give me a good off axis response. I wanted to get some opinions before I go out and buy it. I'm useing HiVi M5N and M8N for the other speakers.
peerless 1" dome
Any thoughts?
Old 18th August 2006, 03:01 AM   #2
BobEllis's Avatar
I don't know that tweeter, but for a few bucks more, why not go for the Seas H1189 A.K.A. 27TDFC. It measures extremely well, according to www.zaphaudio.com and others. Zalytron has them for a few bucks less than Madisound. Just a happy frequent Zalytron customer.
Oh, and yes, I am using it and it sounds great.
Old 30th August 2006, 11:43 PM   #3
Default Re: Good inexpensive tweeter
peerless 1" dome
Any thoughts?
Hi-Vi K1 ought'ta do the job, it'll be happy to play with its siblings and it's better than the Peerless, yet costs less. In fact it's one of the best values on the DIY market.
Old 31st August 2006, 01:49 PM   #4
TomWaits's Avatar
Default Re: Re: Good inexpensive tweeter
...I like the softdome tweeters. I have found this Peerless...Any thoughts?
I love soft dome tweeters but I have never tried a Peerless Tweeter.
Originally posted by Willitwork
Hi-Vi K1 ought'ta do the job...
The Hi-Vi K1 looks good and you can get it under $10 US! Thanks Willitwork, I think I may try it out too. It looks ideal for a 3-way system. See the suggested cut off point.
My all time favourite cheap dome tweeter is the Vifa D19TD0508 and it looks as though Solen may have a few left. I don't think it is in production any more. I purchased 4 extra units for future projects 'cause I love it so much.
It looks like BobEllis is recomending a very handsome unit. The 27TDFC looks very well made for a little extra cash. It's power handling is very high if that is important to you. I'd be interested if any one has listened to this tweeter?
Tweeters are usually the hardest part of a speaker to get right (for me) as I usually match the tweeter to the woofer after I have selected the woofer. When you get a poor match you know it. I have not built a 3-way speaker in many years but it may be easier than setting up a two way as you are only looking at the highest portion of the frequency response of the tweeter and ignoring the lower portion of it's response. But that too depends on the crossover frequencies you are using.
Shawn.
Old 31st August 2006, 03:29 PM   #5
Default Re: Re: Re: Good inexpensive tweeter
Originally posted by TomWaits
[B]The Hi-Vi K1 looks good and you can get it under $10 US! Thanks Willitwork, I think I may try it out too. It looks ideal for a 3-way system. See the suggested cut off point.
If you order a pair of K1's you'll see why I'm convinced they are being sold way under cost, at least in North America. For some reason they are listed upwards to 59 euros on some European suppliers websites, and even at that price they're considered a bargain. The K1 is very similar to the Dynaudio D-28 both in looks and sonic character.
With regards to Vifa I spoke with someone at Solen a few weeks back and according to them Vifa drivers are being phased out by Tymphany, the company that now owns Scan Speak/Peerless/Vifa. Apparently Tymphany wants to carry only two lines of drivers: value-oriented Peerless that will be made in China and high-end Scan Speak made in Denmark. Apparently the Peerless V-line division, which is a sort of life-support for Vifa, is only temporary. Affordable Vifas are already getting scarce, the only drivers still being manufactured are the higher end Vifa Premium Line units.
Old 8th September 2006, 03:46 AM   #6
Default HiVi K1
The Hi-Vi K1 looks good. I would be worried about the power handling capability. spec says 15Watts as compared to 130Watts of the peerless.
Old 8th September 2006, 04:57 PM   #7
Speakerholic
Cal Weldon's Avatar
I have the K1's in my HT system. I find them very good value for the money. To test them, I ran some Supertramp at about 100 watts. They are crossed over at 3K with a 12 dB. I don't think you have to worry about power handling. Heck of a tweeter for the money.
The only disadvantage I see with them is that with such a large motor comes a large flange. This makes them unsuitable for multiple tweeter installations.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 8th September 2006, 06:23 PM   #8
Default Re: HiVi K1
We don't know how these specs are measured, so it's hard to compare. Peerless doesn't mention crossover slope and frequency range used for power handling rating, and apparently Hi-Vi doesn't publish power handling specs the same way most European and North American manufacturers do.
If you had seen the K1 you would agree that Hi-Vi obviously doesn't mean to say that it can only be used in speakers rated 15 watts or less, especially considering that even crappy portable blaster speakers can handle that nowadays. In fact the K1's have such a huge magnet and sturdiness to them that I wouldn't be surprised if Hi-Vi simply pumped 15 watts' worth of pink noise into them and seeing they survived, rated them accordingly.
Now, if you throw 130 watts at the Peerless tweeter (or any tweeter) chances are pieces of dome material would be catapulted through the room with impressive velocity. Obviously this driver has been rated while operating well within its frequence range, and properly filtered.
Old 8th September 2006, 06:32 PM   #9
BobEllis's Avatar
Some manufacturers rate their tweeter power handling in terms of actual dissipation, others like Seas (and probably Peerless) use the system rating with a high pass filter at a specified cutoff frequency and order, usually 2nd order.
For example, (since I have the data sheet handy) Seas rates the 27TBFC/G at 90W long term maximum power with a 3kHz 12 dB/octave filter in accordance with IEC 268-5. The IEC standard undoubtedly specifies the frequency content of the unfiltered signal.
Unless clearly spelled out how it is rated, a power rating is worthless. Even spelled out clearly, it doesn't mean much to me. I think distortion tests such as Zaph and other publish are much more meaningful. Just keep it operating in the low distortion zone.
Old 8th September 2006, 06:35 PM   #10
Originally posted by BobEllis Unless clearly spelled out how it is rated, a power rating is worthless.[/B]
Bingo. They don't call this rating "nominal" for nothing.
inexpensive tweeter to match vifa TC18WG-15-08 SQ Kid Multi-Way 15 7th August 2004 05:21 AM
Good Inexpensive Starter Amp Kit desert rat Tubes / Valves 5 13th June 2004 11:02 PM
Good inexpensive heatsink source? Doovieman Chip Amps 12 3rd November 2003 06:33 PM
Page generated in 0.12356 seconds (81.09% PHP - 18.91% MySQL) with 11 queries
