Old 18th August 2006, 07:29 AM   #1
Lightbulb Adding a pair of Jensen 302A tweeters to two way speakers
Hi Everybody,
I need help from an expert in building crossover of vintage speakers. Friend of mine built a pair of speakers using his own design cabinet and crossover with a JBL midrange LE5-2s and Stephen Trusonic 12R Full Range woofers (or JBL D131A). Those speakers were built for the Jensen coaxial two ways but added an extra midrange (hence two ways). I want to add a pair of Jensen RP302A tweeters to the speakers and connect directly to the binding posts. This is what happened most of sound came out from tweeters and midranges but less from woofers. Then I switched to connect parallel with woofers I can hear most of midrange and bass sounds but very little high from the tweeters.
What should I check and redo or add to the crossovers? Please send me your suggestions or opinions or advices I would appreciate your help. Thanks in advance.
Old 19th August 2006, 01:30 AM   #2
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Use a 2,2 uf cap in series from +speaker input, to the tweeter.
-input straight to the tweeter.
Old 23rd August 2006, 04:58 PM   #3
kevinkr's Avatar
You'll probably need an LPAD to use with these as well as the x-over cap as the RP302 is pretty efficient. One other thing to bear in mind is that these may be 16 ohm drivers, 16 ohm lpads are no longer available, however an 8 ohm lpad should work fine. (Worst case add a 16 ohm power resistor in parallel with the tweeter.)
www.kta-hifi.net
FS: Pair Jensen F15LL 15" FC Woofers + Power Supply nullspace Swap Meet 4 19th September 2008 01:58 PM
ID'ing a pair of Jensen speakers Hass Multi-Way 0 3rd January 2008 06:56 AM
2nd pair of speakers adding adrrad Multi-Way 2 24th January 2007 05:42 PM
adding tweeters to full range speakers. legendaryfrog Full Range 15 22nd November 2006 06:19 PM
Page generated in 0.07712 seconds (69.70% PHP - 30.30% MySQL) with 10 queries
