Old 17th August 2006, 10:37 AM   #1
Default Woofer suggestions (UK)
Hi everyone
I've decided to rebuild my current speakers (floorstanding, SS 9500 + Audax HM170Z0) into a small sealed box and add an active bottom end crossed over in the 200-300Hz range.
It doesn't have to reach into subsonics, as I'm planning on using it for HT and everything under 60Hz will be handled by the subwoofer.
Does anyone have experience with the Scanspeak 21W/8555-01? It seems to fit my requirements perfectly, 35-45L sealed box with an f3 around 50Hz and it's FR looks reasonably smooth upto 1Khz. Knowing SS it will be well built and low distortion, but does anyone have suggestions for any other drivers I should look into as the SS it quite expensive?
I'd like a sealed box around 40L, high resolution clean bass down to around 50Hz with reasonably high power handling.
Suggestions welcome
Rich
Old 17th August 2006, 11:04 AM   #2
tinitus is offline tinitus  Europe
I cannot recommend 21w8555
Old 17th August 2006, 11:38 AM   #3
Dag is offline Dag  Sweden
Dag's Avatar
Peerless HDS Nomex 8 (830869)
16l => fs=75 & Q .7
Old 17th August 2006, 11:57 AM   #4
16l => fs=75 & Q .7
That looks promising, well priced too
Have you used the SS tinitus? What are it's good + bad points?
Rich
Old 17th August 2006, 12:58 PM   #5
SS - With a lot of work it plays ok - hard to "get down" in midbass, but goes very deep but also a bit uncontrolled, though extra magnets helps a bit
If very critical it somehow tends to "live its own life" and difficult to integrate, which I reckon is partly due to uncontrolled ressonance
Right now it plays very good though, but slightly "soft", and I wouldnt use it again
But if listening to "HipHop" and such it might be very good
I have heard the kevlar version with foam surround should be much better - modified I guess
Old 17th August 2006, 01:09 PM   #6
Dag's Avatar
You can compare the 5.5" Scanspeak-15W8530K00 and Peerless HDS 830873 at http://www.zaphaudio.com/5.5test/compare.html.
Not the same size but.........
With a 2nd order LP butterworth (active) on the 830869 at 75Hz you will have a 4th order L-R. Perfect to integrate to the sub.
http://www.linkwitzlab.com/Pluto/subwoofer.htm is a good link for the integration with the sub.
D
Old 17th August 2006, 01:25 PM   #7
I would choose a 10" or 12", but 8" HDS Nomex does look good
Ah, you have sub, THEN you are able to choose one with the best midrange quality
I think this one looks good and probably cheap too
http://www.tb-speaker.com/detail/1208_03/w8-750a.htm
Old 17th August 2006, 01:43 PM   #8
badman is online now badman  United States
Custom Title
badman's Avatar
16l => fs=75 & Q .7
I use a variant of this driver myself, the 8" so nice that I have 12 of them. I use it in 20-30 litre sealed boxes, and am happy with it.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Sub-woofer amp suggestions hybridfiat Subwoofers 3 29th May 2008 03:25 PM
Suggestions for good 6.5' woofer Greg F Multi-Way 0 11th July 2007 06:27 AM
Woofer suggestions for MTM anonymoose Multi-Way 6 7th June 2005 07:13 PM
Woofer Suggestions For PR170MO? delwon Multi-Way 4 31st December 2003 10:59 PM
Page generated in 0.08381 seconds (84.88% PHP - 15.12% MySQL) with 10 queries
