Old 17th August 2006, 03:41 AM   #1
mlankton's Avatar
Default Scan speak floorstander project?
I have looked all week, and I haven't found a project that fits what I am looking for.
If anyone knows of an MTM, TMM, or TMWW project using Scan speak drivers, that is reasonably efficient (87dB or better), and has a nominal impedance of at least 6 ohms, please post. I found a Scan speak MTM, but it was 4 ohm nom and used 5.5" drivers where I want 6.5 or 7". I have considered the 2.5 clone, but I really want something in a 2 or 2.5 way MTM or TMM, or else a 3 way TMWW. Have also looked at the SP38, but I fear it will be more forward than I am wanting with the dome mid.
Basically what I really want is something a lot of people want, a D38 clone, but that isn't a possibilty at this time afaik. Hell, I would be happy with a Studio 140 clone.
If you know of a project that is along these lines, please point me toward it. Thanks
Old 17th August 2006, 04:10 AM   #2
infinia is offline infinia  United States
infinia's Avatar
Default here ya go
I haven't tried these, but seems reasonable to what you're looking for.
http://audioclone.free.fr./previn1.html
Could run the woofers in series( 1st find 4 ohm coils). Inductors and caps in LF crossover would double in value. Because of loss in sensitivity (series conn.) need to pad the tweeter down 3dB. Or consider a new amp that can handle high currents.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 17th August 2006, 08:29 AM   #3
johnny1 is offline johnny1  Greece
johnny1's Avatar
99.9% of the woofers i know have 8 Ohms impedance.
If you use 2 of them in parallel you will have a 4 ohms Speaker. Period!
I think that connecting the woofers in series, will cause you more problems.
The difference between a kid and an adult is the cost of their toys…
Old 17th August 2006, 09:53 AM   #4
Have a look here , might give you some ideas.
http://audiocomponents.nl/speakers/s...erence_eng.htm
Old 17th August 2006, 10:20 AM   #5
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
Hi, should find something suitable here, /sreten.
Old 17th August 2006, 11:40 AM   #6
Alfetta87's Avatar
Default Previn
Most Scan-Speak's are 8 Ohms, you might find some customized 4 ohms version at the german distributor:
http://www.aos-lautsprecher.de/indexE.html
They have an 18W/4XXX in 4 ohms.
The Previn is quite old in design now (1994) and was intended to be a copy of the Response 3.0 from Proac (whilst Proac is using different drivers though, not available for DIY).
But they sound somewhat different, the crossover totally different. I know because I was the designer of the Previn back in 1994...
Why don't you want a 4 ohms design? Most of actual amplifiers can handle this impedance easily.
- dan
It is worth to keep your mouth shut and let people think you’re stupid; rather than to open it and thus eliminate any doubts...
Old 17th August 2006, 12:57 PM   #7
johnny1's Avatar
Another idea is to use one 8" driver. It has almost the same effective piston area as 2 x 6.5"
If the speaker hight is still low for a floorstander, you can always extend the sidewalls to make it look like one.
Old 17th August 2006, 04:56 PM   #8
mlankton's Avatar
18W/16531G is 16 ohm.
Old 17th August 2006, 04:56 PM   #9
mlankton's Avatar
Default Re: Previn
I know I am opening myself up to ridicule by revealing my motive for wanting an easy load, but here it is.
I have a B&K 200wpc amp. It's up to driving just about anything. However, it's a mosfet design, and runs hotter than just about any ss amp you ever saw, and it's location is not the best ventilated spot I could have it in. However, it IS the best spot I could have it in as far as what I have to work with for placing my equipment in my home theater. I fear that if it was driving a harder load I would have heat problems forcing me to relocate it, and I just don't want to do so at this time.
Old 17th August 2006, 04:56 PM   #10
mlankton's Avatar
Another alternative I have considered is the Eton 8.2 3 way. Anyone have any thoughts on the Eton kit?
Scan Speak 23W sub Pan Subwoofers 15 26th December 2007 06:13 PM
My Vifa/Scan Speak Project - Solen Premium kit conscious Multi-Way 7 3rd December 2007 07:43 PM
Scan-Speak project spedmetal Multi-Way 6 2nd February 2006 10:17 PM
Scan speak floorstander with 2 woofers tech.knockout Multi-Way 21 17th January 2006 09:35 AM
DIY project for Scan-Speak 15w/8530k01 2Bak Multi-Way 15 12th February 2003 10:05 AM
Page generated in 0.12663 seconds (79.86% PHP - 20.14% MySQL) with 10 queries
