newbie Q
newbie Q
Old 16th August 2006, 02:23 PM   #1
memphissound is offline memphissound  United States
Question newbie Q
Hey guys. This question obviously reveals my newbie status.
I'm looking at the different components for 2-way "Pro-sound" enclosures (12 or 15 inch woofers, and compression driver with horn). The woofers are rated at something like 300-500 watts, and the drivers at 30-40 watts. Built with a passive crossover.
Here's my question. How come the driver is rated at aproximately 10% of the power rating of the woofer?
Thanks for your help in understanding.
peace,
memphissound <><
Old 16th August 2006, 02:26 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
newbie Q
Because the horns are more efficient you don't need to feed them as much power.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 16th August 2006, 02:32 PM   #3
Default power?
But what about the power that's being fed into the cab? If you're pushing the enclosure with 200 watts (for example) why don't you fry the compression driver? Where is the excess power dissipated? In the L-pad?
Thanks again.
peace,
memphissound <><
Old 16th August 2006, 08:31 PM   #4
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
newbie Q
it never gets to the tweeter because of the crossover (which will have a pad in it
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th August 2006, 10:10 PM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
newbie Q
The big power is used up in driving the lower frequencies to the big woofer cone. It doesn't take a lot of power to move a little compression diaphragm. Therefore the tweeter is able to handle whatever the power is when the woofer is at it's 500 watts. Usually around 10% of that of the woofer. As Dave mentioned, the XO makes sure the low notes don't get to the tweeter.
planet10 needs your help:
Let's help Ruth and Dave
Old 17th August 2006, 06:42 AM   #6
francis varkey is offline francis varkey  India
I'm sure Cal meant to say 10% goes to Tweeter.
You may refer to the attachment, it shows the percentages involved.
I had saved it from the net some time ago.
File Type: gif power distr. for speakers as per freq. range.gif (4.5 KB, 71 views)
Old 17th August 2006, 08:59 AM   #7
Did it Himself
newbie Q
To clarify, a 'pad' refers to an L-pad which attenuates the drive signal.
Old 17th August 2006, 11:36 AM   #8
Default Thanks...
Muchas gracias,
to everyone for the insight. I had contacted a guy at Eminence who gave me similar input. If anyone is interested his reply was:
"High frequencies are not as abusive as lower frequencies, there's not as much information. You can consider the HF device receives only a percentage of the system power. Some general rules of thumb are from 1.5kHz-2.5kHz the HF device receives 20% of the system power, from 3.5kHz-4.5kHz, 15% and from 5kHz up, 10% (this is assuming you're using at minimum a 12dB/octave slope)."
peace,
memphissound <><
newbie QHide this!Advertise here!
Yet another newbie hell0un1verse Introductions 1 30th March 2006 05:31 PM
SET kit for newbie Grahamt Tubes / Valves 9 7th June 2004 02:22 PM
Newbie w/ sub ?'s toenail Multi-Way 2 8th March 2003 01:10 PM
Newbie needs serious sub help AcidRain Multi-Way 4 7th March 2003 07:07 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Copyright ©1999-2017 diyAudio
