Old 16th August 2006, 03:33 AM   #1
Default Driver (speaker) for voice intelligibility
Can anyone recommend a driver that could allow building a speaker with exceptional voice intelligibility?
The speaker will be used mainly for radio reception so in addition of the above, an acceptable performance for music over the limited bandwidth would be welcome.
Thank you,
M
Old 16th August 2006, 04:07 AM   #2
What SPL, size (enclosure), and budget requirements are there?
Also, how wide a range (angle) must it perform for?
Old 16th August 2006, 06:15 PM   #3
Dear 454Casull,
I am not much concerned with SPL, sensitivity in the 88-95 dB/m/w is fine.
I would prefer smaller enclosure, I was thinking about a driver 7 inches maximum.
Budget, do not know less than $400?
M
Old 16th August 2006, 06:22 PM   #4
frugal-phile(tm)
planet10's Avatar
Your best bet for maximum intelligibility would be a good full-range. Given that you want some bass my 1st choice would be Fostex FE127e (modified), 2nd a set of CSS FR125s.
Depending on the set of compromises you need to make there is a large number of possibilities.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Is there any hope for a driver with a rubbing 39mm voice coil? kappa546 Multi-Way 10 7th May 2009 09:38 PM
Measuring driver's acoustic centrer, voice coil distance wigginjs Multi-Way 2 3rd June 2007 03:21 AM
Best midrange for intelligibility of voice rick57 Multi-Way 175 26th April 2005 07:52 PM
Connect cable to driver, don’t sizzle voice coil? rick57 Multi-Way 3 18th February 2005 08:52 AM
Page generated in 0.07855 seconds (72.72% PHP - 27.28% MySQL) with 10 queries
