| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
I have a large number of 3" drivers coming my way and intend to try my hand at building a line array.
Searching this forum, I've seen instances of sealed, ported or open baffle line arrays. I'm wondering if a TL type might work too. Bill Fitzmaurice has something like this (TLAH). Like the TLAH, I intend to build mine to be corner loaded, but am considering a larger number of drivers (18 - 20 ) . Questions regarding the bass-mid bass tuning: 1. I haven't yet got an idea of the driver paramters, but I'm suspecting an Fs of around 100 - 150 Hz. Let's assume a line length of 2 metres for convenience. In a TL loaded line array, .. the drivers are positioned pretty much all along the length of the pipe. Does it make more sense to partition the line into two smaller lines of 1 m each for a quarter wave line freq of 85Hz, or maintain a straight 2m line of 42 Hz qarter wave frequency. I realize that these numbers can be misleading as the drivers would load the line throughout its length, not just at the closed end. 2. Would it be better to taper the line, .. or mass load the terminus, or both. 3. Also, any reccomendations on the cheap 20c parts express onkyo tweeters vs. the apexjr tweeters (50c each i believe) Sorry if the questions seem naive..
"Any fool can know. The point is to understand" - Albert Einstein |
#2 |
#3 |
I recommend that you arrange centers of all drivers on a "curve" that represent a radius from your ears
#4 | |
1. mass loading the terminus with a port 2. maintaining two short TL sections (upper and lower), . without bothering with the extra folds as in your diagram. As for a curved array suggestion, I'll fight that battle next, after deciding upon the bass alignment.
#5 |
One of the projects on my todo list is to try one of my OB arrays as a TQWT. I believe that multiple drivers will help smooth out the typical lumpy Voight pipe response. Additionally, it would be a much easier construction than what you have pictured and the cab height for the array will be part of the line length.
Everyone has a photographic memory. It's just that most are out of film. |
#6 | |
I do wish the TL Gods (Dave, GM, Martin ...)would add their 2c of wisdom
#7 |
The wings on my array are tapered, so it already has a TQWT shape and the conversion would be easy. A straight MLTL is an option as is a multi-driver BIB horn (see the fullrange forum). It just depends on how big you are willing to go with the footprint. As drawn yours looks more like a giant vent BR to me.
#8 |
As far as I know, in a TQWT it is very important where in the "line" you position the driver, so I guess LineArray isnt suited fore this
#9 |
Why not simply make it into a double BR, the simplest is often the best, but admittedly not the most exciting
#10 | ||
![]() Quote:
| Thread Tools | |
| Transmission Line ADD ONS | caratje | Subwoofers | 10 | 4th January 2006 10:49 AM |
| Line array tweeter line - On left or right? | dhenryp | Multi-Way | 4 | 10th March 2005 12:35 AM |
| proposed transmission line array | kneadle | Multi-Way | 12 | 25th July 2004 10:19 PM |
| how to combine Line array and transmission line together | Jared | Multi-Way | 5 | 19th April 2004 11:32 PM |
| t-line subs for a DIY line array | tom1356 | Multi-Way | 17 | 28th December 2002 01:15 AM |
| Page generated in 0.22596908 seconds (86.03% PHP - 13.97% MySQL) with 11 queries |
