Why new xover sounds recess and lacks dynamic
Old 13th August 2006, 08:06 PM   #1
andy2 is offline andy2  United States
Default Why new xover sounds recess and lacks dynamic
My speakers are based on Eros construction but I am using my own version of xover:
Here is the construction and description of speakers:
http://www.speakerbuilder.net/web_fi...oject/eros.htm
I attached my own version of xover. The one on the right is slightly modified from the one on the left.
But the sound of the right xover sound quite rescess but the change is so minimal. Could anyone explain why?
My purpose is to add a bit more baffle step correction so to add a little of warmness to the sound. Any suggestion is welcomed.
Old 13th August 2006, 08:15 PM   #2
Jonasa is offline Jonasa  Belgium
The right on has a resistor in serial with the capacitor in the woofer crossover. The effect of the resistor is a faster roll off in the high frequenties of the woofer (1 ...3 Khz).
My filter has also a resistor in serial with the cap and I did some measurements when I removed the resistor of not.
But does anyone know the reanson why this is?
Old 13th August 2006, 08:21 PM   #3
What's the difference in the sound when you remove the resistor?
I once had a pair of Living voice speaker with the xover almost exactly the same as mine (drivers are almost the same too) and its xover also has 1.5ohm in series with the cap.
Old 13th August 2006, 08:57 PM   #4
When you remove the resistor (0 ohm) you will hear a little more in the frequentie range between 1 and 3 khz.
I"ve the build the studiomonitor of Vance cookbook and did the test but I don"t hear much difference I only saw it on the frequency plot.
Old 13th August 2006, 10:31 PM   #5
lndm is offline lndm  Australia
You may find that the rolloff is a little smoother with the resistor in place. If you like the sound with the resistor removed, you might also try it with the resistor in place but reduce the value of inductance.
Old 13th August 2006, 11:19 PM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Resistors affect phase, timing and Q values and prevent peaks/ringing
I think you you should try a resistor on 0.33mH also
But not easy to say, every component added or taken away affect phase
But do some longperiod testing with different resistor values - I often use rather big R values close to DC resistance, more or less
I also use double RC, cant do without them
Also I recommend RC on tweeter to deal with rising impedance at high frequencies
Old 13th August 2006, 11:42 PM   #7
How about keeping the 1.0ohm resister but reduce the cap from 18.2uf to about 12uf?
Old 14th August 2006, 11:35 AM   #8
Does anybody know a free program on internet where you can play with filter components and see the result on a graph?
Old 14th August 2006, 12:16 PM   #9
R.I.P.
Default Re: Why new xover sounds recess and lacks dynamic
Because the resistor is drastically affecting the Q of the LC section.
Without the R and using "standard" c/o values often results in a
peaking response due to the inductance of the bass unit preventing
the resistance of the driver damping the Q of the LC section.
/sreten.
Old 14th August 2006, 12:56 PM   #10
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Have a look at the PCD or SCD and other stuff at the
FRD Consortium. You might have to use a couple to get what you want and SPL tools is very useful.
No longer DIY active
Why new xover sounds recess and lacks dynamicHide this!Advertise here!
Visaton BG20 hissing and lacks Bass filholder Full Range 6 26th January 2007 01:17 PM
friend lacks midbass - need help! jaygeorge1979 Car Audio 11 8th March 2006 01:44 AM
Routing the recess? xyrium Multi-Way 49 14th July 2005 01:54 AM
To recess or not to recess AntM Multi-Way 4 23rd June 2005 04:58 PM
What to do if tweeter recess is too large Goldenboy Multi-Way 12 25th February 2005 09:26 PM
