Old 11th August 2006, 04:00 PM   #1
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Default Planning an NSB line array questions
Looks like I'm going to be purchasing 30 4" NSB drivers shortly...so all I need are two more to get the 32 I need
Thinking about a 16 per side line array...just a few questions though.
1. I'd like to use one tweet/planar in the middle...what should I go with? I was reading where people had used Dayton PT2B's, BG Neo 8's, and others...the Dayton one is attractive from a price standpoint. Are planars even needed, would I get good results from a regular silk dome from Vifa or Morel?
2. What size enclosure should I build for these?
Thanks in advance
Jim J.
Old 11th August 2006, 09:11 PM   #2
GuyPanico's Avatar
If you're going to use a single tweeter in the middle, it needs to be extremely efficient. A regular dome, or planar tweet will be dwarfed by the array. 16 speakers is a boost of 12db over a single driver. You would need a pro audio driver. And it needs to be more efficient then your line array. A 16 driver NSB array is around 100db (88db+12db) if wired for 8ohms. So you need a tweeter that is probably AT LEAST 103db.
line array build questions and pictures lolojr1 Multi-Way 18 15th April 2008 01:09 AM
coaxial Line Array Questions/comments Toast_Master Multi-Way 16 12th May 2007 10:22 AM
Newbie, Line array questions with TC11MG Vifa and TB 25 RAAMaudio Multi-Way 10 18th December 2004 03:10 PM
Line Array Ruminations and Questions (long) cytokine Multi-Way 28 21st October 2004 12:13 AM
A couple of (goofy?) line array questions.... mpmarino Multi-Way 1 8th August 2004 09:54 PM
Page generated in 0.07700 seconds (67.35% PHP - 32.65% MySQL) with 10 queries
