Old 9th August 2006, 10:25 AM   #1
Default T-M-W-W question
I have a question regarding a project which is in T-M-W-W configuration.
If I change the layout to W-T-M-W would the crossover need to be changed ?
Andrew
Old 9th August 2006, 11:06 AM   #2
Probably a real dumb question , but I'm a newbie....
I ask because I've read there is a difference in crossover design between T-M-M and M-T-M.............so..............
Old 9th August 2006, 11:14 AM   #3
ralphs99's Avatar
Hi Andrew,
IMO no. While the response will be altered somewhat in the region of the crossover between M-W, the crossover frequency is probably low enough (<200Hz) that room effects will probably be more important than the speaker's on-axis response in determining the sound of the speakers.
Cheers, Ralph
Aeronet research pages
Acoustic, Electronic & Speaker Design
Old 9th August 2006, 11:45 AM   #4
Default Re: T-M-W-W question
Andrew
No as long as the hieght (ear level) of T/M axis is not changed.
There are big differences due to T/M c/o frequency.
/sreten.
Old 9th August 2006, 05:39 PM   #5
Nothing's a dumb question. Yea while i'm not completely sure as long as the center to center distance between the woofers is close enough for the crossover frequency it should be fine. But i'd expect some changes when you move off axis...though i'm not sure what these would be.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.08723 seconds (75.72% PHP - 24.28% MySQL) with 10 queries
