parrellel inductors, values add up?
You but notice the inductance is turn^2. Remove half the turns you will get 70% of the original inductance.
No you get 25% of the inductance: 0.5^2 = 0.25
So remove 30% (and keep 70% ;) ) to get app. half the original inductance.
If it was all that easy… First, how do you know how many turns a given inductor has? Second, the inductance is related to the enclosed cross sectional area of the windings. This is not the same for every turn.
Westrock2000, if you need 1.36 mH and you can get 1.4 mH why bother? That is just a few percent off and accurate enough.
To get an accurate value, the best way is to buy a value to first higher value available. Then indeed trim it down by removing turns AND use an inductor-measuring device by trial and error until you get the value needed.
I am using this one and it works pretty well for LS crossovers:
I have no L meter. What about take a known capacitor with the unkbown inductance in series. Feed some sine from a signal generator in this, use a scope to look at the waveform. Turn sine generator frequency for lowest amplitude on scope screen . Read frequency on generator and calculate L ?
