In an attempt to reduce 'spare driver mountain' I'm planning to use a pair of 8" Volt BM220.8s and a Morel USA MDT-33 to make a new centre speaker in the usual horizontal MTM config.
Now the $64k question is should I have a flat front (all 3 drivers in the same plane) or should I angle the mids outwards slightly? Basically ___ or \_/ I'm glad I have a projector as this centre will probably suck the picture off a CRT at 10 paces |
#2 |
you would do far better if you can do a w t/m w set-up.
ie use the 8's up to around 300-400, then have a tweeter over say a 4" mid in the centre. easier flat construction too. |
#3 |
I thought about Mt/mM as I have some audax HM100Z0 4" mids but the Volt 8" plays clean to 3k. Beaming will happen but is that an issue with a centre? (plus the fact the MTM changes the dispersion anyway)
#4 |
You need to do some of axis measurements of FR on the volts, and see at what angle they roll start rolling off. For the sake of argument, say you've got up to 10 degrees to play with before your 3K response gets compromised, you then use that 10 degree off axis measurement to calculate your crossover rather than the straight ahead FR. Does that make sense?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
I forsee some time spent with the table saw and router making some test boxes
#6 | |
You're only really worried about the crossover frequencies, so just get a couple of,say, 1m squares of chipboard, hinge them together in the middle with gaffa, then mount the drivers on them. At the frequencies of interest, back wave isn't a problem, you're only looking at it around the crossover area. If you wanted to get really technical, you could put another strip in the middle with the tweeter on it, then just flex away!
#7 |
Really should get my measurement mic built, I've only been working on the PCB for 6 months
#8 |
#9 |
'Life's Good' - that's oh so poignant when there's 2xVolts and Audax's best mid in the same shot. |
#10 | |
| why is the tweeter angled upwards ? | Bigun | Multi-Way | 1 | 14th April 2009 03:20 AM |
| angled on wall mounting | Theli | Multi-Way | 4 | 4th May 2007 05:08 PM |
| Angled Center Channel? | bickeler | Multi-Way | 4 | 23rd April 2006 01:43 AM |
| How to dado angled joints?? | Jer | Multi-Way | 3 | 5th December 2003 03:43 AM |
| Are angled braces necessary? | PWatts | Multi-Way | 5 | 17th July 2003 10:58 AM |
| Page generated in 0.10367 seconds (75.70% PHP - 24.30% MySQL) with 10 queries |
