Enclosure for high Q driver
I have a friend with a 15" driver and he wants to use it for public address and light music, and to mount it near a bricked ceiling corner. I have measured 44Hz and Qts=1.3.
I could use some suggestions on what enclosure type to use. I am hoping not to need to resort to active EQ, though the corner boost with the high Qts concerns me. |
Seems to me your only option is a sealed box and knocking back the bass EQ knob somewhat. The high Q in box will then control the effective bass extension. More common than you think, see : http://www.partsexpress.com/projects...oys/index.html :0/sreten. |
I have use drivers with higher Qts and it is not possible to get lower system Q unless with active solutions. With passive solutions an IB would give Qs=Qts at best. Smaller boxes with produce Qs even higher than that.
Some options to consider 1) aperiodic vents for weak motor drivers (ie acceleration Bl/mms) 2) Open or semi-open back enclosures for stronger motor drivers (like the old guitar combo amps) |
Looks like a suitable driver for open baffle, although such an 'enclosure' has some disadvantages when used for PA.
Also, according to the author from the alpha-TL article any driver's suitable for alpha-TL loading. You could run some simulations if you're interested in TLs |
I couldn't find anything on "alpha tl" but out of curiosity i modified the parameters of a 15" pro woofer to equal the limited specs that were given above and ran some simulations. The results were interesting. This hypothetical driver shows a huge bump of 6 to 7 dB in a rather large closed box (about 4dB IB) So OB is the obvious usage but not too practical for PA.
So I tried a few things in TL and was able to get a sim that showed broad ripple of about 2dB over the range from just under 30Hz to about 80Hz with sensitivity of around 105dB/W. But get this. The pipe cross sectional area was 8000 cm^3. :bigeyes: An interesting thing to play with but I wonder about the accuracy of simulations when such way out sizes are needed. It would be interesting to have the complete parameters of the driver for further play. mike |
I like the idea of a lossy box of some sort, even if I'll need to resort to a little EQ.
I've loosened the driver up a little and fs has dropped to 37Hz. Haven't remeasured Qts but working with 1.2 till I do. Added mass Vas measured 122l (4.3'^3). Edit: This driver has a fairly light paper cone for its size (in my experience), adding 147g of mass reduced fs from 37 to 26.5Hz. Suspension seems a little stiff (pleated doped cloth) and magnet is approximately 15cm*2cm. |
Adding mass raises Q and reduces sensitivity. Not the right direction, IMO.
Either apply EQ or live with the high Q. If you will be playing rock/pop people will probably like the extra punch. |
According to WinISD Pro a 100 L closed box with an (active) 1st order HP filter at 85 Hz gives pretty nice results. F3 at ~50 Hz, max dip/peak is 0,32 dB.
For PA (at higher volumes) excursion is an important factor, so you might reduce box size even more to gain more power handling. |
<edit>oops just noticed it was a 15" so mms would be a little higher than 50g, you can estimate by looking at similar drivers with known T/S. |
2 Attachment(s)
OK, I was tossing up whether to go with a box much smaller than Vas and deal with the consequences, or make one closer to Vas. I began to sim the baffle step and luck kicked in. I chose a box as large as Vas and used the two largest dimensions for the front.
The red curve is from 'The Edge' baffle sim, the blue is the box response (it is plotted where it is for better visibility), and the green is the resultant. :cool: |
| All times are GMT. The time now is 12:49 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
