Any rules of thumb for choosing a port diameter? I know too narrow will cause whistling. Is there any disadvantage of going too wide? Other than port length increasing.
#2 |
#3 |
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#4 |
Did it Himself
Required diameter will depend on tuning frequency, and driver excursion and surface area. As frequency goes lower the required vent diameter does also.
You can never have too big a diameter really.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 | |
So, as long as it is tuned to the proper frequency. Going with a wider/long port, has no audible disadvantage as opposed to a skinner/shorter port? |
#6 |
Did it Himself
Well if you went insane with the size you would experience more midrange leakage through the open vent, but other than that, the bigger the vent area the smaller the wind noise and compression effects, distortion etc.
#7 |
I got some equations for port diameter. Or simple, my correction of Xmax to Xe.
First, I calculate Xe (real excursion, depend od SPL, Sd etc.) Looks simple, but was long time to get it. Mixed from many formulas. Xe=k1*Sd*sqr(Re)/(BL) where k1=0.68/(0.68+Qts)+0.28 Fb=(0.383/Qts+0.142*Qts)*Fs Dt=a*sqr(Fb*Sd*Xe) where a=(Qts/0.28)^0.8 Last is well known formula, but in original its Xmax, which is wrong, because Xmax is physical dimension, not real excursion. Xe is real excurion at some usual max. RMS power and around frequency of max. excursion (above Fb) which is 1.4-1.45*Fb. And correction factor a. |
#8 | |
#9 | |
XLS 12" Netto volume is 38-41 L, Dt=75-95 mm, and Fb=26-28 Hz. So, in that little box you must make a tunnel as long as 450-600 mm. Ouch! Maybe:
| Why big port diameter? | Jay | Multi-Way | 22 | 13th March 2007 11:52 AM |
| Port Diameter | jwatts | Subwoofers | 18 | 19th May 2006 11:22 PM |
| Minimum Port Diameter | Narcisse91 | Subwoofers | 13 | 22nd March 2006 07:31 AM |
| Basic Q about port diameter(s) | joensd | Multi-Way | 2 | 29th April 2004 06:19 PM |
| Port Diameter Question | BAM | Multi-Way | 3 | 14th November 2001 01:19 AM |
| Page generated in 0.10354 seconds (75.63% PHP - 24.37% MySQL) with 10 queries |
