help, need some figures
Old 6th December 2002, 11:09 PM   #1
Alex_B is offline Alex_B
Default help, need some figures
hi guys,
does anyone have/know a link to find the following numbers:
Linear Exercursion - Xmax & Exercursion - Vd
for:
Vifa M25WO-49-08
and if possible Vifa C17WG-69-08, Vifa D26NC-15-06
thanks in advance,
Alex
Old 6th December 2002, 11:42 PM   #2
Pete Mazz is offline Pete Mazz
http://www.d-s-t.com/vifa/index.htm
Should have everything you need.
Pete
Old 6th December 2002, 11:47 PM   #3
that's where i've got everything so far except for Xmax and Vd, vifa don't state the xmax or vd
unless they are codewords for something else?
Alex
Old 6th December 2002, 11:48 PM   #4
is Xmax Air Gap height?
Old 7th December 2002, 12:15 AM   #5
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Hang on-got the figures right here. Take a moment to calculate.
Air Gap Height is part of the Xmax calculation. Will explain momentarily.
Old 7th December 2002, 12:19 AM   #6
thanks bud, so can you work it out with a formula from the stats provided from vifa?
if so the D26NC-15-06 datasheet can be found HERE as d-s-t only have the newer 55-06 version,
if you use a formula can you provide it so i can work out future xmax values,
thanks in advance,
Alex
Old 7th December 2002, 12:36 AM   #7
Wizard of Kelts
First the formulas for Xmax and Vd
Xmax = maximum one way excursion-from center to extreme
Vd = Volume of air displaced, (moved), by the driver.
Sometimes Xmax is given as front-to-back linear travel, but it should be given as center-to-end.
Here are the formulas:
Old 7th December 2002, 12:51 AM   #8
Wizard of Kelts
For the Vifa M25W0-49-08:
The Effective Diaphragm Area, (Sd), = 346 square cm.
The Voice Coil Height is 14 mm. The Air Gap Height is 6 mm. Therefore, the Linear Xmax is (+ or -) 4 mm.
Therefore, Vd = 346 sq. cm times .4 cm = 138.4 cc.
For the Vifa C17WG-69-08:
The Effective Diaphragm Area, (Sd), = 143 sq. cm.
The Voice Coil Height is 12 mm. The Air Gap Height is 6 mm.
Therefore, the Linear Xmax = (+ or -) 3 mm.
Therefore, Vd = 143 sq. cm times .3 cm = 42.9 sq. cm.
For the Vifa D26NC-55-06, (the new substitute for the 26-15)
Effective Diaphragm Area, (Sd) = 7 sq. cm.
The Air Gap is longer than the Voice Coil by .5 mm. I assume that means it can move linearly (+ or -) .25 mm. Don't hold me to that. It's a tweeter anyway-things are different.
Estimated Vd = 7 sq cm times .025 cm = .175 cc.
By the way, mechanical Xmax for woofers is usually 1.5 to 2 times the Linear Xmax.
Do you have the response charts for the C17 WG? If not, they are located here:
http://www.mass.com.au/masssales/pdf/C17WG-69-08.pdf
I'll recheck the figures and edit if necessary. If I am off on the calculations, as an American I can blame it all on Metric!!
Old 7th December 2002, 12:54 AM   #9
thanks,
now when the software calculates port sizes, when you chnage from 1 to 2 ports the length doubles plus a bit.
for e.g.
currently with one port 66mm diameter and 100.4mm long when i change to two ports @ 66mm diameter i get 249.1mm length.
now is the 249.1mm the total length for both ports or 2 ports @ 249.1mm length? being around 500mm total?
thanks,
Alex
yes i have the charts
Old 7th December 2002, 01:01 AM   #10
Wizard of Kelts
That would be 249 mm for each port tube. Each tube will be 66 mm times 249 mm.
help, need some figuresHide this!Advertise here!
Distortion figures for analog muxes eplpwr Parts 39 26th June 2013 01:08 PM
Lissajous figures rtarbell Everything Else 1 28th October 2005 02:23 AM
Noise Figures northsiderap Solid State 12 7th May 2005 09:48 AM
Xmax figures to actual exurcsions? TRANSDUCEReng Subwoofers 20 21st September 2004 09:19 PM
DC offset figures johnm Chip Amps 7 6th February 2004 02:01 PM
Copyright ©1999-2017 diyAudio
