Old 27th July 2006, 12:10 PM   #1
Default Svante's Basta! speaker simulator trial
I've been playing around with the trial version of the above,
http://www.tolvan.com/basta/
modelling the bass response of the Martin Logan Monoliths
is this thread Help, need good LF 12'' (300mm) driver
With some very interesting / bizarre results with the standard
driver. If only Basta! also modelled congugate impedance
peak compensation, which it really should for mids/tweeters.....
/sreten.
Old 29th July 2006, 08:53 AM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Hehe...
Basta! can model such networks in the € version. There is a tab named "advanced network" that can be used for any passive network that has a common ground for input and output.
The user interface is a bit more crude than for the other passive networks, and a schematic on paper with node names is a big help. On the other hand almost any configuration is possible.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 30th July 2006, 11:31 AM   #3
Hi Svante,
As far as I can tell it cannot do what I said it should be able to.
Yes it can (disabled) have a conjungate impedance at the input,
but it cannot have RLC circuits directly across the drivers post
the passive crossover network. This is common for tweeter and
midrange resonance peak suppression and also for suppression
of metal cone bass / mids resonances.
/sreten.
Old 30th July 2006, 11:38 AM   #4
Svante's Avatar
No, you'll have to move everything to the advanced network, including the filter. But that's a piece of cake...
Old 30th July 2006, 11:55 AM   #5
OK,
didn't realise that was possible (should have read
the documentation more thoroughly, it is quite clear
on the point). Possibly it would be friendlier if it was
part of the standard interface - but it is possible.
/sreten.
Old 31st July 2006, 10:53 PM   #6
Svante's Avatar
Well, the advanced network is sort of my way out whenever people want additional crossover configurations added...
Please don't say "allpass"...
How to represent a speaker for a simulator destroyer X Solid State 15 6th February 2009 08:14 PM
New version of Basta! released. Svante Multi-Way 18 26th December 2007 08:03 PM
Basta! software problem. ashok Multi-Way 7 20th June 2007 01:09 AM
Svante's the EDGE Pano Multi-Way 11 20th January 2007 09:57 AM
Basta! loudspeaker simulation software Svante Multi-Way 0 13th August 2005 02:57 PM
Page generated in 2.54197 seconds (4.01% PHP - 95.99% MySQL) with 10 queries
