Looking for good bass to 200Hz
Old 26th July 2006, 11:41 AM   #1
hugobors is offline hugobors  France
Default Looking for good bass to 200Hz
Hello,
I've an open baffle that cover the 200Hz 20Khz frequency range at 96db/1W/8Ohm. So I'm looking for a good bass woofer to go with...
Problem is that I prefer it to be passive, so exit OB woofer because no equalisation.
I prefer close cabinet for transcient response and lit's ess boomy than bass-reflex.
So what's your opinion about having dipole above 200Hz and monopole under 200Hz.
And do you have some opinion on a good closed box from the lower frequencies to 200Hz.
I had the idea to put 4 10" in serie paralel configuration to achieve good bass response, and sensitivity in the 96db range.
Do you have some opinions on this or oder ideas...
Old 26th July 2006, 12:17 PM   #2
Virtalahde is offline Virtalahde  Finland
After lots and lots of thinking, I'm probably going to use Peerless SLS-8's afterall in closed cabinet. I'm gonna use two for some ~90dB sensitivity, in a cabinet of 150 litres or so. Maybe bigger.
SLS-8 (and SLS-10) should give F3 a tad under 50Hz. For 96dB sensitivity, you could use 3 woofer per side. Cabinet for 3 could be about 150 litres minimum (for qtc=0.707), but bigger would be better.
EDIT: The load would be difficult with three woofers though..
Old 26th July 2006, 12:42 PM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
When you say passive, do you mean you want to restrict yourself to a passive crossover, or just not use EQ?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 26th July 2006, 12:44 PM   #4
Magnetar is offline Magnetar  United States
Banned
Not sure you can get the Madison 21" woofers where you live - no eq needed
Here is what I did with them on an open baffle
Old 26th July 2006, 03:44 PM   #5
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Hugo,
with limiting yourself to passive x-overs you are cutting your one leg. And with constricting to monopole bass below 200 Hz you are cutting your other leg. Which leaves you paralyzed. Thatīs IMHO
I know this is a harsh metapher, but let me explain:
Getting some plate amp with an appropriate LP x-over or a stereo amp with some passive-line-level x-over will give you much more choice in the woofer compartment for a lower price than investing in high efficiency woofers.
And avoiding dipole operation where it works best for you (below 200 Hz) can only be excused if size is a real problem for you. Both simulation and experience have led me to the conclusion, that the cancellation of (some) room modes which you get with that dipole bass is more helpful to the reproduction of music in a room than the "spaciness" which dipole mids can give you.
So it would be a pity if you stop short of a fullfledged dipole system.
Rudolf
www.dipolplus.de
Old 26th July 2006, 07:22 PM   #6
Thanks for all your replies....
My first idea was to be in all passive configuration, thats means passive crossover without EQ.
Yes I know that dipole for bass is very good, and reduce room mode. I've heard the jamo r909 and was very impressed with their bass.
So do you know how they do their EQ? Of course it's in a passive way, that's why I'm interested in... And do you think it's possible to do the same with a lot of 10", a little less 12", less 15", 18", or like magnetar : 21"?
Hugues
Old 27th July 2006, 12:03 AM   #7
Notax is offline Notax  Montenegro
Notax's Avatar
Hugues [/B]
Allmost imposible mission, bass dipol and get 96 dB/1W/1m. Look at Jamo 909. Its 2*38 cm basses, probably 95-96 dB each, two in parallel 98-99 dB, but dipol gives -10 dB. So, its 88-89 dB/1W/1m at bass, and probably 1-2 dB less for mid.
In your case, where you need finaly 96 dB, you need 4 bass units for each channel. 101-102 dB per one, +6 dB for four (parallel+series) -10 dB in dipol, its 97-98 dB (minus 1-2 dB over passive x-over). That means 4*18" basses with high efficent.
All this means much much power. Again, active is (allmost) inevitable. For dipol specialy.
If the passive is your final decision, I think you can only go with one 18" (or bigger) 8 Ohm bass with 97-98 dB efficient in bass-reflex enclosure.
Any other way is active or death.
Old 27th July 2006, 08:14 AM   #8
Did it Himself
Going active would bring far more benefits than the level matching as well.
Old 27th July 2006, 11:52 AM   #9
Rudolf's Avatar
Hugues,
as Notax already explained, you will not get bass dipole action at 96 dB/1W/1m passively. Jamo, I believe, are attenuating those woofers heavily from 40 to 250 Hz (theoretically it should be almost 15 dB, but 10 dB certainly are more realistic). So you need REALLY efficient woofers and REALLY big amps and REALLY expensive fat copper coils to get some bass out of those woofers
And do you think it's possible to do the same with a lot of 10", a little less 12", less 15", 18", or like magnetar: 21"?
If you do not have the means to equalize actively and donīt want to destroy a lot of power, you need drivers with a low Fs and a very high Qts. With Qts=2 and Fs=30 Hz you get a natural 6 db rise from 80 to 30 Hz which could compensate for the dipole loss. But you would have practically no rise from 200 to 80 Hz. So this could only help for a pure subwoofer application.
Rudolf
www.dipolplus.de
Old 27th July 2006, 01:45 PM   #10
Ok, so, to stay in dipole, the best solution is to be in active.
But do you think I can stay with one amp and only do bass boost?
And if yes, one thing I don't like is feedback, so to do an active bass boost, is it possible to do this :
PHP Code:
sign----+-----buff--------------------------------------Sum-------To power amp
12dB--------filter low pass 6dB------------!
Looking for good bass to 200HzHide this!Advertise here!
Kickbin, 80-200hz flat? Wisounds Subwoofers 1 12th August 2009 03:46 PM
FE166e used only above 200hz............. norman bates Full Range 22 26th March 2009 11:10 PM
15" Bass Driver for OB (40-200Hz) OTMOPO3OK Subwoofers 60 12th September 2007 08:21 PM
200hz sub regal Subwoofers 2 9th January 2004 02:38 AM
Copyright ©1999-2017 diyAudio
