Old 25th July 2006, 05:44 PM   #1
banana is offline banana  Hong Kong
Default Helmholtz bass absorber, where to place?
If i measured an 10dB in room response bump at 60Hz, and would like to tackle it with a tuned passive radiator, where should I place it?
At the node (high pressure zone)? or at the anti-node (high velocity zone)?? Which location would gives a better result
Old 25th July 2006, 06:57 PM   #2
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
Hi Banana,
I don't have a specific answer to your question, but when I am solving resonance problems, I always turn to Ethan Winer. His advice is tuned more for recording engineers, but the principles are sound.
There are two resources, his site and his forum:
site
forum
I hope that helps.
Dave
I have a small website for my projects.
Old 25th July 2006, 08:08 PM   #3
The high pressure zone, (some off the pressure dissapears when the passive membrane is moving) or you can place solid things in the air moving zone (it stops the air from moving)
Jens
Old 26th July 2006, 04:13 PM   #4
great link and very helpful info
Thanks.
Banana
Why do they place tweeters far from the mid-bass? poldus Multi-Way 11 22nd October 2008 03:34 PM
Cheap Absorber/Diffuser LineArray Full Range 6 16th August 2008 12:19 AM
Aeropanel acoustic absorber ralphs99 Multi-Way 46 18th September 2006 12:50 AM
Dont want mr. Helmholtz in my sealed sub ! Coolin Subwoofers 18 14th October 2005 09:13 PM
Any experience in designing a Helmholtz bass trap? MarceloSQ Everything Else 4 5th July 2002 07:33 AM
Page generated in 0.06116 seconds (80.06% PHP - 19.94% MySQL) with 10 queries
