Just in case someone's interested: 16 ohm woofer
Old 25th July 2006, 04:52 PM   #1
3-LockBox is offline 3-LockBox  United States
Default Just in case someone's interested: 16 ohm woofer
Here's a woofer I ran across at MCM Electronics...
It isn't quite 'fullrange' enough to post over there, but efficiency is pretty good considering its a 16 ohm speaker and it might make a decent wideband driver, and could be used in a D'appolito or line array.
http://www.mcminone.com/product.asp?...5Fid=55%2D1620
You might have to contact the manufacturor for more detailed info, as MCM doesn't always post the most comprehensive specs list. And their search engine sucks too.
(insert clever anecdote here)
Just in case someone's interested: 16 ohm wooferHide this!Advertise here!
room gain in case of dipole woofer? graaf Multi-Way 15 10th December 2008 07:47 AM
Found these feet in case anyone is interested. Wildcard26 Multi-Way 0 6th June 2008 05:09 PM
What to use for a case ???? la9 Chip Amps 3 22nd August 2004 03:34 AM
DIY Case dhole Pass Labs 9 15th August 2004 02:47 PM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
