Old 24th July 2006, 06:03 PM   #1
Default Want to try out a new speaker design, give me pointers
Hey all, it's time to take a break from the trunk beaters and get back into hi-fi. Last time I fooled around with the hivi full ranges (B3S and B3N), I didn't find the low bass extension I like. So here's what's up next, I'd li ke you to critique this for me:
D'appolito design with:
http://www.partsexpress.com/pe/showd...number=295-360
http://www.partsexpress.com/pe/showd...number=275-070
All through a 2nd order LR filter in a floorstanding design. I haven't made the a design yet, just looking to see if these are comprable drivers.
-Dave
Old 24th July 2006, 06:22 PM   #2
infinia is offline infinia  United States
infinia's Avatar
Not much bass to be had here either, unless you are doing something tricky on the crossover design. PS think about either a notch or a much steeper LPF for the midbass, lots breakup due to metal cone.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 24th July 2006, 06:25 PM   #3
So what would you suggest in that case? 4th order?
Old 24th July 2006, 06:27 PM   #4
Or what about one 6" centered with the same tweeter? I really couldn't push those two 5"s if I wanted to (100 watt/6ch 3 yr old receiver here)
Old 24th July 2006, 06:34 PM   #5
infinia's Avatar
I think there is a design using RS180's in an MTM alignment on a another site ( Home Theater or something) So you could find it and scale it for your smaller drivers. Should be better for the tweeter to use your smaller drivers you can cross it a little higher up.
Old 24th July 2006, 06:39 PM   #6
Not sure if I can afford even two of the 7's (yes I know the dual 5's are more expensive, but I can get them for very cheap secondhand from my neighbor who didn't use all of the 6 he got (still new)) as I'm only 17 and couldn't get a job this summer. Still need to build a box for my RL-P (I say it like that so that if I ever need any cash, I can just unhook it form the ep2500 and sell it as is to a teenager who wants it in his trunk), so we'll see. Thanks for the help.
Old 24th July 2006, 06:49 PM   #7
infinia's Avatar
MTM's are not easy to design period. And then using metal cones to boot adds a few more layers of complexity. Keep looking for designs/ and recommendations around here. You can build something nice for not too many$.
Old 24th July 2006, 06:53 PM   #8
kvholio is offline kvholio  Netherlands
kvholio's Avatar
probably much easier to filter, and one of these will outperform 2 of the daytons you mentioned:
http://www.partsexpress.com/pe/showd...number=297-302
Klaas
Old 24th July 2006, 07:12 PM   #9
FastEddy's Avatar
Default OK, got crossover suggestions?
" ... probably much easier to filter, and one of these will outperform 2 of the daytons you mentioned: http://www.partsexpress.com/pe/show...tnumber=297-302 ..."
OK, got crossover suggestions? ... ready made or DIY ... in conjunction with a bodacious sub woofer & bright, high res. tweeter with a knee @ about 4K.
Old 24th July 2006, 11:20 PM   #10
infinia's Avatar
FastEddy
Here you go
need some pointers to find the right design Lifthanger Full Range 33 6th August 2009 08:10 PM
i need some openions....please give me feed back...speaker design... slicemaster101 Multi-Way 219 23rd August 2008 02:34 PM
33 Power Pentode Design Pointers Needed mario2 Tubes / Valves 0 25th September 2006 05:22 PM
preamp pointers name773 Solid State 1 24th April 2004 05:43 PM
Anyone who have been to the Northwest DIY, please give opinion on this speaker. zoooh Multi-Way 3 28th March 2003 02:27 PM
Page generated in 0.09599 seconds (79.14% PHP - 20.86% MySQL) with 11 queries
