Old 24th July 2006, 02:19 AM   #1
Question Gain
I've been looking around for a good answer for this question but I cant seem to find one so I'll ask. What does gain do on an amplifier for example. I know sort of what it does but I was wondering how it works from an electronics standpoint. Any comments appreciated.
Old 24th July 2006, 02:39 AM   #2
lndm is offline lndm  Australia
Maybe less of what it does and more of what it is. Gain is a change in signal level. It is typically measured in dB's. It applies generally in physics, not just electronics.
Naturally, changing the level of a signal (increasing it) is the job of an amplifier. Hope this helps.
Old 24th July 2006, 03:25 AM   #3
vinylkid58's Avatar
Check this out:
http://www.allaboutcircuits.com/vol_3/chpt_1/4.html
Jeff
Old 25th July 2006, 02:36 AM   #4
So what i am getting from your 2 replies is that gain is just an increase in voltage from one point to another, and the sound that comes from gain is because more current is being pumped through a loud speaker than should be. Is that all right?
Old 25th July 2006, 03:12 AM   #5
ShinOBIWAN's Avatar
Is it not the case that gain is never really applied to the input signal per-se but its actually attenuated at anything other than 0dB. Of course the amplifier stages do their job of increasing output suitable for loudspeakers.
Actually that makes little sense thinking about it
Maybe I've been around digital for too long
Old 25th July 2006, 07:24 AM   #6
On a different note, a gain can be negative but it often depends on how you use it. A device could be said to have a gain of -3dB, but overall you would say it attenuates the signal by 3dB.
The thing that pumps current is voltage. You don't force more current through something, rather, you increase the voltage and more current flows.
Gain is simply calculated by taking the amount of voltage (or current or power) at the end of a circuit and dividing this by the amount of it at the beginning of the circuit.
Gain Blockwith Variable Loop Gain Bonsai Solid State 17 11th July 2008 02:40 PM
How much gain should I have? komen Chip Amps 2 26th March 2006 01:32 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Unity Gain Operation (or low gain) Tomo Chip Amps 12 22nd January 2004 01:47 AM
Q on amp gain Andrey Solid State 1 18th June 2002 09:48 PM
Page generated in 0.09668 seconds (72.55% PHP - 27.45% MySQL) with 10 queries
