Old 20th July 2006, 08:17 AM   #1
Luke352 is offline Luke352  Australia
Send a message via MSN to Luke352
Default Budget DIY, I tried searching
Hey Guys and Gals, I'm just trying to make up some budget tower style speakers for home, this will be my first dive into home audio, but I am quite into Car audio and currently run an IDQ15" sub and have a set of DLS UP36 3 way splits, so I do like nice sound. Now here is the challenge at this moment I'm currently just looking for drivers cheap ones, I've been looking at some of the Jaycar/Response stuff thats about my budget of course cheaper would be great. Now they will be going into a 6x6 metre room and will be used for movies and music, and size isn't to much of an issue being sensible of course, a sub setup will come later probably and I will probably find an amp capable of about 2 x 100wrms. I hope you guys can help me as I really don't know where to start as far as home audio goes.
Thanks heaps guys.
p.s. I'm sorry this has probably been asked before but I did search and didn't really find what I wanted.
Old 20th July 2006, 09:54 AM   #2
Just thought I'd add you can get some of this Morel Car audio equipment very cheap over here in AUS.
http://www.fastfoursforumscarclub.co..._pricelist.pdf
I would possibly look at the tweeters but I'm not sure maybe a bit more then I wanted to spend considering I've heard very good things about some of the vifa tweeters.
Thanks again
Luke
Old 20th July 2006, 10:48 AM   #3
Cheap drivers and no idea about hifi crossover design = poor sound.
Cheap drivers can be used, but you need measuring equipment and a very
large dose of knowing exactly what you are doing to achieve good results.
Far field listening in a real room is far more complicated than setting
up car systems, and car systems are a lot more flexible + less critical.
If a sub is going to be added a simple pair of stand sealed two ways is best.
If no sub is going to be added a floorstanding MTM vented two way is best.
(Or a floorstanding TMM 2.5 way)
Halfway house between the two is a stand mounted sealed MTM.
Going cheap on the drivers doesn't make a lot of sense given the
time you will spend making a decent pair of cabinets (and stands).
Seas + Vifa are available in australia, checkout :
http://www.zaphaudio.com/audio-speaker16.html
/sreten.
Old 20th July 2006, 12:32 PM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
I also think it is a good idea to say what you call 'budget'! That term means quite different things to different people depending on their circumstances!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 20th July 2006, 08:14 PM   #5
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Morel drivers, car audio
if typically Morel, then they are excellent and the crossovers are quite good as well. The biggest problem is making sure you have complete parameters.
stew -"A sane man in an insane world appears insane."
Old 21st July 2006, 10:15 AM   #6
I'm liking the look of the Waveguide TMM, and the Vifa XG18/ Seas 27tdfc MTM from the Zaph webpage, the cost of conponents is about the top of my budget, any other suggestions guys otherwise I may try one of those.
Luke
Old 21st July 2006, 03:26 PM   #7
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
I think what we mean when we say "budget is in the eye of the beholder" is that you name a real dollar figure.
For example, when I build a budget system, I mean to spend about $200-300 USD on components.
When someone else means to build a budget system, he spends $1-2K USD.
Still a third person might mean to spend $30-40 USD.
All are legitimate, and all can result in fine sound reproduction, given the quid pro quo, sine qua non, et. al., usw, usw...
If you name a dollar figure, people here can direct you where you want to go.
Dave
I have a small website for my projects.
Old 21st July 2006, 09:45 PM   #8
Around $200 US for drivers and crossover components is about my budget with a max of about $300 US. I'm too concerned about cabinet costs as it doesnt have to look that good along as they are perform I don't really care what they look like.
Thanks again
Luke
Old 21st July 2006, 10:08 PM   #9
Default check this design out
at Rabbitz site
http://www.rzaudio.com/rz52/Floorstander.htm
simple design, not expensive,
& easy to get good results
Old 21st July 2006, 10:11 PM   #10
ScottG is offline ScottG  United States
'JASD' (Just A simple Dipolspeaker)
Ciare 250
perspective is everything
searching a ESX Q 275.2 or 175.2 pit bull Car Audio 1 7th December 2008 08:46 PM
WTB: budget mic and pre set fishball79 Swap Meet 0 5th December 2007 08:22 AM
Searching... Cortez Forum Problems 1 27th April 2006 12:23 AM
How bad is budget? Pbassred Solid State 10 27th March 2004 06:53 PM
Searching for this guy Guss The Lounge 1 3rd August 2003 11:04 PM
Page generated in 0.11096 seconds (78.41% PHP - 21.59% MySQL) with 10 queries
