Old 17th July 2006, 08:35 PM   #11
Originally posted by 454Casull
So no BSC circuit is necessary for OB speakers?
Dipole output drops 6dB/octave with decreasing frequency plus there's a +6dB peak where the back and front waves combine in-phase.
Dipole roll-off can be corrected for by using (shelving) low-pass filters on the bass drivers (Linkwitz Orion, Phoenix, etc.) or very high-Q drivers where sensitivity decreases with increasing frequency (Bob Carver Amazing dipoles, probably Gillmore Audio).
Wide baffles can push the effect lower in frequency so you get away without equalization.
You can use notches to correct the peak or just cross-over lower to keep it out of the driver's pass band.
You really want to visit www.linkwitzlab.com
Baffle dimensions being significant compared to typical listening distances mean the cancellation isn't as complete as the math predicts, so you might get away with less correction.
John Kreskovsky and Siegfried Linkwitz both have measurements of this effect.
Old 17th July 2006, 10:25 PM   #12
Rudolf is online now Rudolf  Germany
Rudolf's Avatar
Originally posted by Drew Eckhardt
... plus there's a +6dB peak where the back and front waves combine in-phase.
This peak is only 6 dB for a driver in the center of a circular baffle. For "normal" baffles this peak can be sufficiently attenuated by positioning the driver off baffle center. Again EDGE is a nice tool to accomplish that.
Rudolf
www.dipolplus.de
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 08:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 11:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 30th November 2004 12:09 AM
Open baffles & baffle step 5th element Multi-Way 13 15th April 2004 07:44 PM
Page generated in 0.09455 seconds (72.15% PHP - 27.85% MySQL) with 10 queries
