Hi, guys, i want to build two 3-way Loudspeakers for listening music and another 2 Way system for my Front HT System. i really want to use the better speakers that i can, my budget is like 1000 U$S / Each speaker.
I want to cover full range of frequencies in my front speakers. I will use an amp for each driver (so i will need like 8 channels for the fronts+center speakers. i already have an 3 tweeters but are not 100% sure if i want to use it because are not so good (like others), so maybe i can resell it or just build another boxes for my surround speakers btw, the tweeters that i have are Aurum Cantus G2Si maybe i can use it in my surround and purchase anothers for my front channels.... Thanks for your help in advance |
#2 |
What driver brands are available in Argentina?
Here's one good option, Troels's Acapella SE: http://www.troelsgravesen.dk/diy_lou...pella%20SE.pdf |
#3 |
here is impossible to find any brand, i need to purchase from any other place (USA, China, Europe...)
I readed some good comments abt SS, Eton and many others... i will check your option. Thanks |
#4 |
WOW, your link looks great!
You know if someone have measure these Box? i really think that looks amazing |
#5 |
I think Troels has measured them quite thoroughly. You can find more of his designs here:
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm Tony Gee's site: http://www.humblehomemadehifi.com/ |
#6 |
Thanks too much! i really want to play with this tweeter! i really never hear it (and never hear an ribbon tweeter).
The best that i listen was an B&W 602 S2 is really not easy to find good hifi systems in my city, i need to drive 300km to buenos aires, there im sure i can goto listen good equipment.btw, i just will play with this ribbons but i will order anothers 3 tweeters (dome ones) to play with it too. |
#7 |
All in Argentina are damn expensive and Hard to find, the only that i can get an good price are Polk Audio Loudspeakers. i really was thinking abt purchase any of these to change my old B&W 602 S2.
i was checking some kits in Madisound like the Thor, really looks nice, but the problem that i see that Thor works ok going down to 30hz. and for example Polk LSi 15 go down to 22Hz! :S Are the polks one comparable with the thor ? The price of the kit in madisound are 1275.00 / Pair. The polk have 88db and Thor 89db. Sorry for ask that stupid question but i never heard Polk LSi or Thor |
#8 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
ok, so i think that will go for the acapella SE!
to get an center channel according to this Fronts, is ok to purchase 2 more W18EX001 and use it in conjuntion with my other Tweeter? (to create an MTM Horizontal box).? and... for surround ? |
#10 |
It's hard to make a matching center for the Acapella SE, but I would recommend to build something with the same drivers. Troels TJL (using W18E and G2Si) in a smaller closed box for center and surround could be ok. Just remember to keep the front panel width the same as it's with the original.
| Choice of Mid-Range Drivers? | Francec | Multi-Way | 25 | 15th December 2008 02:36 AM |
| Advise on system choice | buggsson | Multi-Way | 2 | 23rd January 2008 03:06 AM |
| Peerless Drivers ... Wise Choice? | HTRookie | Multi-Way | 7 | 12th December 2005 12:58 PM |
| Page generated in 0.13920 seconds (63.85% PHP - 36.15% MySQL) with 10 queries |
